NathanR's Avatar
Send a message via Yahoo to NathanR
Missing Mystery Relay
Hi all,
I've been rooting around in my trunk getting ready to install new H4 headlights in my 87 Carrera. I found a relay base installed on the front bulkhead, close to the front condenser fan (which worked last summer). Its got wires to it, but no actual relay. The wires come from the loom, and look factory.
The relay base had the following numbers on it:
3 334 485 008
The wires installed are
Heavy gauge wires:
Yellow w/ black stripe
Red w/ white stripe
Lighter gauge wires:
brown
light gray (jumped to a second terminal, also)
Anybody ever seen this before?
Nathan
87 Carrera Coupe
Black on Black, H4 Headlights, Nurburgring Sticker
Old 12-30-2008, 06:05 PM
old man neri's Avatar
Ya, I have a relay up there as well, I figured out what it was for but now I forget. Condensor fan relay maybe?
Old 12-30-2008, 07:13 PM
NathanR's Avatar
According to Bentley, the condenser fan relay is #6 on the front fuse/relay panel on my 87.
87 Carrera Coupe
Old 12-30-2008, 07:22 PM
Should be the headlight washer relay.
Old 12-30-2008, 08:04 PM
if not sure I'd jump it with engine running
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-30-2008, 10:01 PM
NathanR's Avatar
headlight washer rly?
I think you nailed it, OSI930. My car does not have headlight washers, which may explain why no relay is installed, but the wire colors leading to the block match the wiring diagram for the "headlight washer control unit" as shown in my Bentley manual.
Thanks all.
Nathan
87 Carrera Coupe
Old 12-31-2008, 08:14 AM
I had the same empty relay port. Got a used relay for the front condenor fan(asked the junkyard to pull the relay by location)
I have put it in but my condensor fan still doesn't work. If I put power to the light grey wire the relay works and hense the fan does. My ac works(compressor kicks on and I get cold air) but the car will not turn on the relay. I am worried that the pressure will get too high in the condensor.
Old 06-21-2010, 09:39 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks all.
Nathan
Hi Nathan,
Did Porsche delete the (useless) headlight washers for the '87 model year?
It was a standard feature on the '86.
Cheers,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-21-2010, 09:56 AM
