Disconnecting fan...simple question
I want to isolate a sound I hear from the block and need to disconnect the main fan. Can someone tell me from where I disconnect it? Do I also have to disconnect the AC motor?
Thanks |
The fan that cools the engine? The big one? You need to take of the belt.
Yes the big fan, I simply do not want it to turn while I listen....so I want to cut its power for a minute...
It is turned via the fan belt you see...
I see said the blind man to his deaf dog......
Thanks, makes sense.... |
by the way.....dont let the engine run long without a fan....or you will be hearing really bad noises of fried engine internals...for what it is worth
| All times are GMT -8. The time now is 01:46 AM. |
