Stranger on the Internet
patkeefe's Avatar
CIS Fuel Lines
I had a no start problem on the 78 SC today. When I went out to troubleshoot it this evening, I quick checked and did have fuel pump operation. In the process of putting my gauges on the fuel distributor, somehow I managed to break off the fuel line from one of the banjo fittings, such that there is only about 3/8" of brass left for the fuel line to connect to. I doubt this is enough, so I need a new banjo fitting, and probably a new fuel line. Our hosts do not seem to have what I need in the catalog.
I did a search, and thanks to Jim Sims, found a link for
http://www.specialtauto.com/ while searching this thread
Cis Lines No Longer Available?
My question is, did the factory swedge the plastic fuel lines so that they fit on the banjo fittings? The end I cut off the bad line went flying somewhere behind the engine, so it is not readily available to examine it.
Should I just replace all six of the lines while I'm in there? After all, it is 28 year old plastic.
I welcome any input on this.
BTW, from what I could tell, I had only 30 PSI of fuel pump pressure (whle holding my finger over the bad banjo fitting). The fuel filter was pretty dirty. When I went to change it, the new one was the wrong model. Then, after I fix this, I can resume troubleshooting. Bad day in the garage.
Pat
Patrick E. Keefe
78 SC
Old 03-05-2006, 06:41 PM
patkeefe's Avatar
Update:
Anyone yet find a source for the extremely elusive metal lines?
Thanks!
Pat
Patrick E. Keefe
78 SC
Old 07-05-2006, 07:46 AM
metal lines
Calson Porsche in Menlo Park Ca, can put togerher a set for you
650-701-9200 and ship them to you
ask for Mike in parts, he can be a little cranky sometimes
Old 07-05-2006, 10:09 AM
