Fan shroud strap?
I can't for the life of me seem to re-attach my fan strap. I didn't take it completely off, when removing the fan/shroud etc.... I can't seem to get the two ends close enough to tighten the bolt. Any ideas...?
86' 911 Carerra |
mine lined up when i rotated both ends toward the extreme drivers side of the engine compartment with the bolt being almost verticle
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
I ended up using a longer bolt, I had a new CV bolt and it's the same size....just a little longer.
86' 911 Carerra |
I did the same thing...a longer bolt. Make sure the fan shroud is in the right position.
Deutsche Fahrzeuge 78' 911SC 03' 325I BMW 03' KTM 450sx 05' S2000 (daughters) |
Just re attached it using channel locks to bring both ends together,aand re-positioned the two ends under the coil mount.
Bruce
HB Kramer (4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete) (2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well. |
