Good Start, Very POOR Idle
Hi Guys,
I need some help. Unfortunately, my 83'SC had to sit for about 3 weeks. Went to start it up this weekend, and it started right up, went to about 2000rpms, and then fell to about 500rpm, and idles very rough. I can slowly work the throttle,and get it back up to high RPMs but when I let off the throttle, it goes back to idling very rough around 500rpm. When I parked it a couple of weeks ago, it was running great. After I get it past 2000rpm, it accelerates great! What do I need to check? What could it be? Thanks |
I woul d guess AAR it probably closes to fast that with the combanation of the WUR being the slitest bit out of adjustment then that woudl give you the problems you have.
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
I also forgot to mention that it will idle so low as to force both the battery and OXY sensor lights to illuminate. Also, I think I hear the pop valve popping.
Designer King
I agree w/ mb911. You should search "mystery train" for his adjustment of the AAR and "WUR" for info on that device. You should also check your mixture and control pressures.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
