-   -   Accelerator pedal bushing - replace? (http://forums.pelicanparts.com/porsche-911-technical-forum/292120-accelerator-pedal-bushing-replace.html)
ecm911 07-06-2006 03:59 PM
It appears the bushing for my accelerator pedal level has broken. The lever appears straight it just wobbles.
Before I pull it out - can this be replaced w/o pulling the pedal cluster? Certainly looks it to me.
Earl
arcsine 07-06-2006 04:31 PM
I suppose it is possible but you will be saving time and grief if you pull the unit out and replace all the bushings.
Look here for the procedure:
http://www.pelicanparts.com/techarticles/Mult_pedal_cluster/Mult_pedal_cluster.htm
ecm911 07-06-2006 04:48 PM
Gary,
Thanks , but all the other bushings are OK its was rebuilt by PO. Not sure it would save any time to pull the whole cluster.
