ecm911's Avatar
Accelerator pedal bushing - replace?
It appears the bushing for my accelerator pedal level has broken. The lever appears straight it just wobbles.
Before I pull it out - can this be replaced w/o pulling the pedal cluster? Certainly looks it to me.
Earl
78 SC Coupe
93 RSA (Gone)
Old 07-06-2006, 03:59 PM
I suppose it is possible but you will be saving time and grief if you pull the unit out and replace all the bushings.
Look here for the procedure:
http://www.pelicanparts.com/techarticles/Mult_pedal_cluster/Mult_pedal_cluster.htm
gary
Old 07-06-2006, 04:31 PM
ecm911's Avatar
Gary,
Thanks , but all the other bushings are OK its was rebuilt by PO. Not sure it would save any time to pull the whole cluster.
78 SC Coupe
93 RSA (Gone)
Old 07-06-2006, 04:48 PM
