cameron.arnott's Avatar
Weber advice needed
I'm currently running Weber 40IDTP 3CI's which I imagine are from the original 2.2 T motor belonging to my car ('71 T) which is in the shed in various pieces. They seem to have original spec internals which are:
Venturis - 27
Main jets - 110
Pre Atomiser 4.5
Air correction - 185
Emulsion tube - F1
Idle Jets - 55 (not original)
Pump jet - 45
Idle Air Bleed - 145
I'm currently running a 2.4 with 'S' cams and 2.2 'S' pistons (higher c/r) and wondered if I should go through the motions of changing venturi's, main jets, emulsion tubes, idle jets etc to suit the more up spec engine?
The car seemed to run ok but I'm wondering if there are performance benefits to be had with making the changes? And are the internals all interchangeable between the 40 series carbies?
Any ideas would be appreciated.
Cheers from the Aussie tropics.
'74 RS 3.0 Replica
Porsche 968 Clubsport SOLD
'70 911E Bahia Red SOLD
'71 911 S/T Replica 2.3 Twin plug BEAST SOLD
Old 07-07-2006, 04:28 AM
jluetjen's Avatar
Yes, I believe that you'll find a fairly noticeable improvement in the mid-to-high rev range by optimising the carbs for a 2.4S engine.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 07-07-2006, 04:40 AM
ttweed's Avatar
I agree with John. Your venturis and jetting are too small for optimum power with a 2.4S engine. See the chart at Larry Turner's site for a better starting spec, and then put it on a dyno to fine tune. Something like 32mm venturis, 135 mains, 180 air correction, and 60 idle jets is suggested for a 2.4S.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 07-07-2006, 07:07 AM
Thanks guys, much appreciated.
Might try Larrys suggested specs for the 2.4S, I assume these parts are all interchangeable on the 40 series carbs?
Im looking forward to some extra horses!!!
'74 RS 3.0 Replica
Old 07-07-2006, 07:47 PM
Adrenaline Junkie
Hayabusa's Avatar
I usually run mine with all of the vents open on the bottom, especially when I am floggin the hell out of it! Try it. You'll agree!
Old 07-07-2006, 08:41 PM
Senior Member
Chris,
Not to worry, when you get things lined out and want to run with the big boys, here is what you will need.
Old 07-07-2006, 09:03 PM
Hayabusa
My mum used to do a pretty good Webber too...
Also the car sometimes stalls under heavy breaking with the clutch in. Any ideas anyone?
Thanks again.
'74 RS 3.0 Replica
Old 07-08-2006, 03:11 AM
dimps8's Avatar
Your float level maybe too high causing flooding at fast stops or steep driveways...I hope your nice and warm up there.
Damon Harris
66 912 coupe
Old 07-08-2006, 03:32 AM
Cheers Damon,
Yeah pretty nice weather up here at the moment...
Hopefuly the carb rebuild might help solve the problem if the floats were out.
Hey have you joined the TYP 901 Register yet?
Cheers
'74 RS 3.0 Replica
Old 07-08-2006, 04:53 PM
One last question (I think) for the carb Gurus.
Is there any differences between the intake manifolds for the early carbied cars and later ones?
And if so are there any worthwhile modifications than can be done to the 'T' manifolds to suit the above suggested changes to the carb internals for the 'S' spec engine?
Cheers & Beers
'74 RS 3.0 Replica
Old 07-08-2006, 09:57 PM
ttweed's Avatar
Originally posted by Joeaksa
Chris,
LOL! When I read this, I flashed on the epic 60+ page thread from 2003 on the Rennlist racing forum about GhettoRacer and driving student's cars. It tangentiated about page 39 into a parody concerning "BBQ events" (BEs) and "Can I drove your grill?" that had me rolling in the aisles. I think it is the longest running thread on that forum, and definitely the best haiku came out of it!
TT
Tom Tweed
R Gruppe #232
Old 07-09-2006, 12:07 PM
