Me like track days
Craig 930 RS's Avatar
Question CIS fuel lines.....other than plating, how to refinish?
930 engine rebuild:
Fuel lines on the 930 look a bit faded and well, shabby.
How to spiff em up without taking them to a cad plating outfit (which is weeks out for the next cad plating batch)?
Any brush on plating 'kit' that would work fine?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 07-11-2006, 10:58 AM
DW SD's Avatar
Craig, Use POR - 15 or Red high- temp engine paint. I did the paint thing with some steel fittings when I redid the old 3.2's high pressure fuel lines. A hydraulics shop brazed the AN-6 fittings to the Porsche metric lines.
I prepped and painted the lines and then baked on at 160 degrees F in the wife's oven. The paint was very durable and looked decent. I think you could buy a small CAD plating kit from Eastwood, if that's what you are seeking. Can't vouch for how good it looks.
Doug
1971 RSR - interpretation
Old 07-11-2006, 12:15 PM
Me like track days
Great! I appreciate it -
Doug, can you post a pic of yours?
Old 07-11-2006, 12:30 PM
DW SD's Avatar
Craig,
Sorry, no. I took a bunch of photos before the 3.2 was reinstalled a year or so ago, but it was a day or two before I had installed the new fuel lines. The Carrera lines are hidden underneath the intake manifold, for the most part, so mostly, I just painted for corrosion resistance. Worst case, you could always remove them and have them CAD plated at a later date. Paint won't hurt anything.
Sorry I couldn't be of more help.
Doug
Old 07-11-2006, 12:36 PM
DW SD's Avatar
BTW - I did not paint the hex heads, so there was no concern that the wrench wouldn't fit or mar the paint.
Doug
Old 07-11-2006, 12:43 PM
