Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Long hood project
Back to work on my long hood project. Removed the turbo flares that were already installed on the car to replace with mid year fenders. After bondo removal, found I needed to change out rockers too.
Started laying out the fender operation tonight. Marked the trim areas on the tub. I need to keep the rear light opening from the earlier car, as the 75 brake light opening is a different stamping.
Outer rockers will be changed too, pass side has a big welded cut in it.
Drivers side will probably take a more traditional flare type cut.
And a rocker
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 04-24-2012, 05:43 PM
D@vid's Avatar
Great project, will be following closely. I intend to start my longhood project coming winter.
1973 2.4 MFI
bone-stock 911T
Old 04-25-2012, 01:12 AM
Stahlwerks.com
jhelgesen's Avatar
Other projects out of the way, back to work. Working the passenger side first, trimming away the bent, rusty, ond crusty bits.
Removed the rusty rockers.
Trimmed the new used fender.
Prepared engine mounts from the same donor car.
Braces gone too.
New ones are factory pieces.
John Helgesen
Old 09-02-2012, 06:39 PM
Stahlwerks.com
jhelgesen's Avatar
Fit the new inner rocker.
Built a few patches at parts from scratch.
Test fit the outer rocker.
John Helgesen
Old 09-02-2012, 06:51 PM
Stahlwerks.com
jhelgesen's Avatar
Started aligning the front fender and door to check the rocker parts. I'm using some fenders and doors from a 75 I have to work with. Not perfect, but straight.
Door gap needs more space.
Needs to be perfect before I secure the rocker.
John Helgesen
Old 09-05-2012, 06:06 PM
wayner's Avatar
Coming along nicely!
SOLD - 914 wide body hot rod
Old 09-06-2012, 05:24 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Nice work!!
Where do you source all those replacement panels??
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 09-06-2012, 05:32 AM
Gillies's Avatar
Good work, keep the pictures coming. Doing a similar project myself.
Gilles...
1970 Targa 911T
Old 09-06-2012, 12:22 PM
Stahlwerks.com
jhelgesen's Avatar
Originally Posted by wachuko View Post
Nice work!!
Rockers from restoration design
Supports and door lock posts from our host
Inner rocker from eBay
Rear patch and jack post reinforcement are scratch made
Rear fender came from a donor car
Thanks, happy to keep pictures coming
John Helgesen
Old 09-06-2012, 12:47 PM
Stahlwerks.com
jhelgesen's Avatar
Got another day on the project, finish fitting and clamping in place with cleco fittings.
John Helgesen
Old 10-01-2012, 10:12 AM
Stahlwerks.com
jhelgesen's Avatar
Took a little break, to rebuild a Motoguzzi, but back to work on the tub.
The guzzi I rebuilt, started here with a hole in the engine case.
Currently here, almost done.
Been welding patches in place.
John Helgesen
Old 01-12-2013, 06:28 PM
ShakinJoe's Avatar
Subd
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 01-12-2013, 06:33 PM
Betcha can't have just 1
strudelwagon's Avatar
Wow, Great detail John. I'm looking at a similar repair on my next project 71T and getting a look inside that sill makes me a little more comfortable with the idea of opening it up.
Cheers
SW
Old 01-13-2013, 09:16 AM
Been awhile since I've seen what you've been up to. Nice work. I will need to do some of what you just posted. Thanks for the photos. Will be helpful.
--Von
Von Whitley
Los Alamos, NM
Old 01-13-2013, 11:57 AM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Love these threads. Thanks for digging in.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 01-13-2013, 06:54 PM
ROW '78 911 Targa
timmy2's Avatar
I have a love/hate relationship with this thread. Every time I look at it, I want to go find a rusty longhood to restore. It's a sickness...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-13-2013, 07:52 PM
Stahlwerks.com
jhelgesen's Avatar
The rocker is in and finished now.
Now I can start rear fender alignment.
Old 01-14-2013, 02:59 AM
Stahlwerks.com
jhelgesen's Avatar
Fender is 95% trimmed in place now.
Old 01-17-2013, 05:20 AM
redturbo911's Avatar
Thats some serious work. Nice job so far. Keep the pics coming.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 01-17-2013, 06:56 PM
Good work. What are the small round parts called that it looks like you are using to thickness align the two pieces of sheet metal on the rear fender? Where are those available from?
Old 01-17-2013, 07:23 PM
