Airfilters ,Do you need them for the track?
Every time I see a race car or pics of race car they don't have a airfilter. It's just open.
Can I run my car at the track with out the air filter. MFI really sound good without them!
Derek Oxford PCA - Nationally Certified Instructor 2002 Boxster S ( race car) 2010 LR4 2009 GMC Sierra (Porsche Support 2011 M3 4Door |
I think the track is actually dirtier than many roads. You'll wish you had them if you go off in a drity area. And, if you read the study on the Early S Registry, the stock air plenum did nothing to inhibit performance and was better than at least one other common alternative.
I'll see if I can find that for you. |
Non Compos Mentis
A race engine's life is measured in hours. A 911 street engine will go for 200,000+ miles, but not if there's grit wandering around.
Hilbilly Deluxe
Re: Airfilters ,Do you need them for the track?
Great input here,... ![]() Without question, the sound track of open stacks is music to the ears and you can still have that by installing a set of either K&N air cleaner assemblies or some ITG filters on your MFI stacks. Unless I had an unlimited engine budget (or a good sponsor), I'd strongly recommend using air cleaners on ANY street or track engine. However,........on the engine dyno, street-type MFI engines make best overall power with the factory airbox in place since that acts as a resonance chamber and smooths the torque curve and A/F plots.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Author of "101 Projects"
Right - I think what everyone is saying here is that most real race motors are torn down after a few races, so the wear from a few specs of dirt are not that important, compared with potential power losses. However, if you have an engine that you'd like to keep around for more than a few race hours, then I would suggest running air cleaners...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Typical air/fuel ratio is maybe 13:1, richer under load.
That's 13 parts of air to 1 part of fuel ....... by weight. Thirteen (13) pounds of air is a tremendous volume of air ingested into the intake tract. The less grit, the better for engine longevity. Sherwood |
