My custom Gt3 intake built by Billet Design
I thought everyone would like to see my finished intake for my turbo engine. It began life as a Gt3 intake and evolved into what you see here. All the fabrication work was done by Marco Manzie at Billet Design.
Looks like it was cobbled up by the tin man -
Just kidding - Man - that donkey does some good work - looks like a work of art - -Jeff
Jeff |
What modes did they have to do to get the GT3 intake to fit?
Also what motor is it going on? BTW it looks beautiful, lots of detail and care was taken. Is it plastic or Alu? |
The intake has been cut and welded for runner length mods etc. He machined injector blocks to work with a 2 bolt head. The motor is a 3.5 stroker motor with a single turbo
pic
Nice...
I'm surprised that the intake on the GT3 is Alu, I always thought Plastic flowed better. Oh well... wrong again. When do you plan to have this motor in action? |
The intake is smoothed over internally
The plenum area on this thing is huge which is great for a turbo motor. It is just a timing deal now to get all the last things bolted on and it is ready to go.
WOW!
user & abuser
that looks wicked
i'd love some more details on your 3.5L stroker turbo.... and some more info on your car... that is going to be an impressive engine bay.
vini vidi vici |
Curious at this budget why you did not go with a full Motec or similar engine management. I see you have the Dizzy still.
Beautiful work!!
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Looks like there are 2 plenums - one on each side?
What model was used to calculate their sizes & placement re runner length?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
WOW, that looks insane, Eric! Very cool
![]() Must have cost a pretty penny
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Navin Johnson
Strokher has had a talented fabricator adapt a throttle body and modify the runners and crossovers to suit.. which look remarkably like the runners on a GT3 RS I know. The last two places this manifold raced were Le Mans, then Watkins Glen This one is from Porsche Motorsport..for a supercup engine.. circa 2001
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Hey Eric I almost popped for the same intake but Marco being the class act that he is told me that for street applications the 3.2 Carrera intake did the job as did Bob Holcombe for that matter. It does look awesome though.
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
Huh?
The one in the pic above has single plenum and it is at least 4x the ones on the red induction unit....
I have a JB racing 12 plug distributor on the engine and a crank trigger. That is the old accel dizzy in the motor.
I'm curious about the twin crossovers, why not just one large one? Seems to me like the front crossover will do little but provide volume. Wouldn't as single crossover centered between the end plenums work better?
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Yes there are two plenums on the intake. Alot of R&D was taken to adjust the runner length etc to get it where it is at. The dyno will be the final test of what it will do. I have my hopes high on this intake
What size/make turbo are you useing?
Sure looks impressive.
79SC driver 77S targa work in progress
