Where did reverse gear go...?
1978 930 – PO said shifter has a short shift kit…
I lost reverse today, literally. I can easily shift and drive in 1st thru 4th but when I try to move the shift lever over to push up into the reverse position it will not move far enough to the left for the transition into reverse. I did notice that in any of the four gear selections the lateral play in the shifter is as great as 1 ¼” inches from the left most position. How much is too much lateral movement in 1st thru 4th? No clutch problems just reverse gear selection. I thought I should seek the board’s wisdom before I start the shifter linkage etc disassembly – any suggestions? thomas |
Any suggestions???
Is the problem most likely in the shifter assembly or in the linkage?
Any suggestions at all? Surely there's a 4 speed expert in the group. |
I would start looking at the coupler. Not because I am a newbie, but since its rather accessible and could possibly cause that symptom.
Much better informed will correct me if I am wrong. Could not hurt to take a look though.. |
your coupler is probably off.
i would replace all of the worn bushings in the linkage as well as realign the coupler.( the wevo coupler is a good upgrade). it is amazing how much this improves the feel of an older 915 |
| All times are GMT -8. The time now is 09:11 AM. |
