Where did reverse gear go...?
1978 930 – PO said shifter has a short shift kit…
I lost reverse today, literally. I can easily shift and drive in 1st thru 4th but when I try to move the shift lever over to push up into the reverse position it will not move far enough to the left for the transition into reverse.
I did notice that in any of the four gear selections the lateral play in the shifter is as great as 1 ¼” inches from the left most position. How much is too much lateral movement in 1st thru 4th? No clutch problems just reverse gear selection.
I thought I should seek the board’s wisdom before I start the shifter linkage etc disassembly – any suggestions?
thomas
Old 07-09-2006, 09:29 PM
Any suggestions???
Is the problem most likely in the shifter assembly or in the linkage?
Any suggestions at all?
Surely there's a 4 speed expert in the group.
Old 07-11-2006, 02:57 PM
durn for'ner
livi's Avatar
I would start looking at the coupler. Not because I am a newbie, but since its rather accessible and could possibly cause that symptom.
Much better informed will correct me if I am wrong. Could not hurt to take a look though..
Markus
Resident Fluffer
Carrera '85
Old 07-11-2006, 03:28 PM
brett25's Avatar
your coupler is probably off.
i would replace all of the worn bushings in the linkage as well as realign the coupler.( the wevo coupler is a good upgrade). it is amazing how much this improves the feel of an older 915
1980 911 SC Coupe
1987 944
Old 07-11-2006, 04:36 PM
