A Quiet Boom's Avatar
Opinions wanted on solid tensioners
My 3.0SC engine doesn't have the tensioner upgrade and sometime over the winter it's going into my '73 shell for use as a track and occasional street car. Rear fiberglass bumper will be installed with Dzus fasteners so rear engine access will be easy. Comparing the cost of pressure fed tensioners against my ability to make a set of the solid adjustable tensioners in my machine shop make me wonder about either buying or making the solid ones. Question is how often will they need adjusted. I can only assume they'll be noisy in a cold engine and quiet down when warmed up, is this true? Anyone have experience with solid tensioners?
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 07-02-2006, 10:18 PM
Early_S_Man's Avatar
Porsche Crest
Christian,
You may not have seen the thread on tensioner rebuild kits:
Chain tensioner rebuild kit part number?
My suggestion would be to get a set of the double-bushing 1980.5 chain-wheel carriers ... mill 10.0 mm off the lug of your old tensioner bodies, and rebuild with three locally-obtained O-rings. I did a rebuild of a failed tensioner in 1979 and it lasted just fine for the three months I was waiting on back-ordered '930' tensioners from Germany! My suspicion is that rebuilds without the factory rebuild kit should be good for a year or two, maybe more, and for no more than about $5 worth of O-rings! That is a lot less trouble than keeping tabs on mechanical tensioners, and lots less $$$ in chain cover gaskets, too!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-03-2006, 04:24 AM
Warren,
I think you mis-understood the question, my current tensioners are fine, I just want some insurance against a failure and was thinking the solid ones might be the way to do it inexpensively. The engine is an '81 and does have the newer chain-wheel carriers. I've heard of racers using the solid ones and I'm just curious about usage on a car that will see 3000-4000 miles a year tops.
Thanks for the thread though. If I where to rebuild them so I know they're in good shape isn't there a bushing or something that can be added as protection against total collapse?
Old 07-03-2006, 08:31 AM
Hi Boom,
I read some good stuff on solid tensioners about a year ago. Do a search to find it. Basic feeling was that most people thought it caused chain wear issues that could lead to failure. Although that really did not make much sence to me. I supose the spring ones give some and help prevent chain strech?
I like them I drive them
Old 07-08-2006, 02:47 PM
I did a search here on Pelican and what I found is that they are fine to run as long as they are properly adjusted. They have to be loose at startup otherwise the chains will put a lot of stress on the cam bearings etc. when the engine is hot and the chains get tighter.
Old 07-08-2006, 04:08 PM
The early tensioners as well as the "Carrera" tensioners work the best because they maintain a constant designed tension on the timing chains.
A bolt type tensioner can be set for the proper tension for a SHORT time. As the chains stretch the fixed bolt type tensioner doesn't respond, so the chain runs looser than design dictates.
Actually the chains don't stretch. Each bearing surface wears slightly. With 98 bearing surfaces, (yes 98), even slight wear loosens the chain.
If you are concerned; use the safety collars.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 07-08-2006, 06:06 PM
That's what I figured I'd do although I've heard of a mod for the early tensioners where you put a bushing inside to prevent total collapse.
Old 07-08-2006, 06:25 PM
competentone's Avatar
The $23 solution sounds easier:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ENGcam_pg5.htm#item13
Chain Tensioner Guards
Protect your engine from premature failure by installing a set of failure prevention guards. The guard slips around the tensioner shaft and prevents complete failure and collapse of the chain. NOTE: Not for pressure-fed tensioners.
Chain Tensioner Slip Prevention Collars, set of 2 [Photo] [Photo]
99-0458-053-M230 $23.00
Old 07-08-2006, 08:49 PM
the mod where you put a bushing inside is for the pressure tensioners. it is called the jerry woods conversion. i saw it on this site, and just did it to my tensioners this weekend. it keeps them from collapsing too far, yet you can still get them installed.
Old 07-10-2006, 03:07 AM
FLATTOP's Avatar
Christian.
It is not called an upgrade for nothing. On my track 2.7 the previous owner ran solid tensioners on a 2.7 motor. On opening the covers we noticed that the gears seemed to take the most pounding. I vote for the hydraulic tensioners even at the cost premium. IMHO
Johan
Johan
www.almost.co.za
Old 07-10-2006, 03:24 AM
