12V lighter
Could I use the cigarrette lighter to power my MP3 player or do I need another type?
'77 911S w/'81 3.0/MegaSquirt/MSD '81 911SC stock |
Another type of what?
Anyway, 12VDC is 12VDC. The power needed for a cigarette lighter circuit should be plenty for any MP3 players I can think of.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
So, any cigarette lighter adapter would work?
Michael Delaney wanna-be
Any type of lighter adapter should work. Just make sure that the lighter housing is clean (good contact means less chance of popping a fuse) and that whatever you plug in doesn't exceed the capacity of the adapter.
88 Carrera Cab C.R.A.P. Gruppe Member #7 |
Administrator
Keep in mind that 911's have the slightly larger diameter cigarette lighter. This can be frustrating with some device's plugs (there are sleeved made to address it) and it's not an issue at all with some other plugs.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
My Valentine had the auto eject thing going when i first used the lighter, so I grabbed the cardboard from a film box and ripped up a section, folded it in half, and curved it to fit. Radar sheilds were in full force from then on.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Yea, I converted over to a permanent power supply...that was just the temp solution!
