Send a message via AIM to EPorsche
12V lighter
Could I use the cigarrette lighter to power my MP3 player or do I need another type?
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 07-10-2006, 06:23 PM
coloradoporsche's Avatar
Another type of what?
Anyway, 12VDC is 12VDC. The power needed for a cigarette lighter circuit should be plenty for any MP3 players I can think of.
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 07-10-2006, 06:56 PM
So, any cigarette lighter adapter would work?
'81 911SC stock
Old 07-10-2006, 08:02 PM
Michael Delaney wanna-be
Netspeed's Avatar
Any type of lighter adapter should work. Just make sure that the lighter housing is clean (good contact means less chance of popping a fuse) and that whatever you plug in doesn't exceed the capacity of the adapter.
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 07-10-2006, 08:39 PM
Administrator
Jack Olsen's Avatar
Keep in mind that 911's have the slightly larger diameter cigarette lighter. This can be frustrating with some device's plugs (there are sleeved made to address it) and it's not an issue at all with some other plugs.
Old 07-10-2006, 08:50 PM
lateapex911's Avatar
My Valentine had the auto eject thing going when i first used the lighter, so I grabbed the cardboard from a film box and ripped up a section, folded it in half, and curved it to fit. Radar sheilds were in full force from then on.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 07-10-2006, 10:27 PM
Netspeed's Avatar
I powered my V1 with the dome light circuit. I have a Cab so I pulled the domelight out, wired it up, and stuffed everything into the cavity. All that sticks out is the phone cord end that plugs unto the V1.
88 Carrera Cab
Old 07-11-2006, 09:23 AM
Yea, I converted over to a permanent power supply...that was just the temp solution!
Old 07-11-2006, 01:53 PM
