ecm911's Avatar
How to tell short shifter?
Quick ?
I have a 915 shifter removed from a 78SC. Some suggested it may be a short shifter. How can I tell? I have never seen one.
The shifter knob is not factory its black leather.
Earl
78 SC Coupe
93 RSA (Gone)
Old 07-11-2006, 05:29 PM
If its real tight to get into 2nd then its probably a short shifter
Currently own:
1980 911SC slantnose
1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because)
2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD)
Gone but missed:
1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade)
1984 Jeep CJ-7 (1994 Chevy Blazer)
1987 Chevy Corvette (1996 Mustang Cobra)
1993 Jeep Wrangler (1995 Mustang GT Conv.)
2003 Ford Explorer Sport Trac (1987 BMW M6)
Future: Hopefully not too far off
Ferrari Testarossa (Lamboghini Diablo or Countach)
Detomaso Pantera
Old 07-11-2006, 05:58 PM
ecm911's Avatar
SlantnoseSD,
thanks for the quick reply. But the shifter is not installed in a car.
78 SC Coupe
93 RSA (Gone)
Old 07-11-2006, 06:03 PM
ecm911, go to Seine systems website and they have a chart with dimensions for all the shifters used in the 911, you should be able to determine which shifter you have, very good site lots of info, I believe the option code is M241, but thats for an 85', I don't know if they used the same code for all years.
85' Carrera
92' Mustang 5.0
02' Focus ZX3 08' FJ Cruiser
Old 07-11-2006, 06:12 PM
Immature Member
dentist90's Avatar
Try this...
This was taken from my 84 and is a short shift lever. Hole to end of ball is about 60mm. A regular shifter will be a few mm less (ie. hole will be closer to ball end). Try this measurement 1st and see what you've got.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 07-11-2006, 06:18 PM
drag racing the short bus
dd74's Avatar
The key is if what you have is a factory short shifter. That's something you definitely want to hold onto -- ur...so to speak.
The Terror of Tiny Town
Old 07-11-2006, 06:32 PM
Dan in Pasadena's Avatar
dentist90 - I know NOTHING about short shifters but if that hole-to-end distance is the only difference, why couldn't a person weld that hole shut, grind smooth and re-drill as a short shifter? Anyone know if this would work?
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 07-11-2006, 06:52 PM
Immature Member
dentist90's Avatar
That's not the only difference... the shifter guide plate (fork) and the pivot housing are also drilled differently so that the ball ends up in the shift lever cup while still using the original housing. If you tried to use the original pivot housing the ball would end up below the cup. The shift lever difference is the easiest to measure and explain.
BTW, Earl... shift knob won't give you any hints about what's below. More a matter of personal taste.
Old 07-11-2006, 07:27 PM
Immature Member
dentist90's Avatar
The shifter guide plate on a short shift looks like this. A reg shift should have opening marked in red:
The pivot housing on a short shift has a convex upper surface with the hole offset. A reg shift will have a symmetrical housing with the hole centered:
Old 07-11-2006, 07:48 PM
...and all that stuff still looks like it would be relatively easily modifiable from the factory parts...or am I being unrealistically optimistic?
Dan in Pasadena
Old 07-12-2006, 07:40 AM
Originally posted by Dan in Pasadena
It is your car, and you got the shifter in your hands. Go for it. What is the worst thing that can happen? YOu'll buy another for cheap.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-12-2006, 08:00 AM
