rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
How to remove oil line from side of motor?
I'm backdating my oil lines to install my SSIs. I can't really get the oil wrench on the nut where the line enters the motor. What can I use?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 07-12-2006, 06:23 PM
Early_S_Man's Avatar
Porsche Crest
Very large 18" - 20" Crescent wrench ... make sure the jaws are tight on the fitting -- no play whatsoever!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-12-2006, 06:34 PM
RETIRED
Joe Bob's Avatar
For the tight areas....Campagnola or Park Bicycle open end wrenches.
2012 ML350 3.0 Turbo Diesel
Old 07-12-2006, 06:37 PM
rs6er's Avatar
If got a n oil wrench I got from Pelican, but I can't get the thing to budge.
John
Old 07-12-2006, 07:22 PM
Porsche Crest
John,
That's what I encountered when upgrading my system to a front cooler, and I used a big 20" long Crescent wrench to loosen the nut! No harm to nut, and I used a much smaller 36 mm wrench to reinstall it back on after modifications, later.
Warren Hall, Jr.
Old 07-12-2006, 07:30 PM
RETIRED
Joe Bob's Avatar
Heat and a counter wrench....and/or a slip over pipe.
Old 07-12-2006, 07:31 PM
safe's Avatar
Are there ever any problems with removing the line from an mag case engine? Damaged threads etc?
Magnus
Old 07-13-2006, 01:20 AM
