Thanks for your comments!
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
cycling has-been
The difference in noise level could be attributable to he thermal reactors? If you are going from ssi's in your earlier car to the factory system on the 77, there is a huge dB difference.
There was for me. By the way, once you get rid of them with a decent free flow sys, oil temps will drop 30+ degrees, and you will no longer have the possibility of boiling the fuel after spirited runs. cis is a whole 'nother beast. Have fun!
73 911T MFI, 76 912E, 77 Turbo Carrera |
Backdating exhaust is on the list...but its down on priority. Should I move it up? The exhaust is stock from the factory. Could this be contributing to the amount of heat I feel around the back of the car after a drive?
cycling has-been
yes, yes, and yes
move it way up on the list thermal reactors are bad...... very, very bad they are nothing but a 12lb(ea) cast iron heat-sink designed to burn off pollutants at super high temps towards Porsche's attempt to stay cat-free. take a close look at the underside of your car to see the dictionary opposite of 'free flowing exhaust system'
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 07-15-2006 at 07:14 AM.. |
Good to know, thanks!
OK, I really need to sell Foxy Brown so I can afford my cheap SC!!
Good to see you here Matt! On the Decel valve, in the early CIS models this was an easy adjustment. The nut on top turns to make it drop quick or slow. Not sure if it is the same on the SCs? Pat |
cycling has-been
Hey Doug, there are alternatives to selling old fauthful. I have most of the parts you need to convert to a euro exhaust sustem, dirt cheap. (2 heat exchangers, and the crossover pipe) that would not work on my short bellhousing 4 speed trans.
Bill K
PM'd you.
![]() PS. I still need to sell old faithful...
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 Last edited by Doug&Julie; 07-15-2006 at 08:50 AM.. |
that day that 'old faithful' sells...i sense a premonition of the blowing of a 'mighty wind'..
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
My 84 oil pressure was pegging out also. I pulled the wire
off pressure sensor and the gauge went zero.. connect peg... I dont think it's good to have it pegged while driving. i'd probable disconnect if it's not reading at all.. then maybe not Mine was the pressure sensor unit. Here's the threads on replacing this if you have AC on the car (use a crowsfeet...)Oil Pressure Sender I had a small issue with getting into 1st gear unless stopped but got larger problems with a clunk... You should be able to get a R&R on the trans... syncho's etc for under $500 bucks LABOR... parts well depends where you buy these. I paid for the parts below $1,230 shipped... last year. So you looking at around $2k to address common wear items. If your looking at gears or heaven forbid bearing you better grab a chair when looking them up. Your bearing should last a long long time if you Do not run metal through them (hint your 1st and 3rd grinds.) I would attend to the trans pronto as it seems to be at a point that would really benefit you to get it done at a reasonable cost. I did a small video of dropping a engine out of my 84 if your interested. taking into account safety issues of a drop. ie. unhook the battery #1... http://www.beams.com/porsche/ Good luck. ALL OEM item unit, cost unit, # units, cost Gasket set 915-300-911-01, 42, 1, 42 Trans fluid swepco 201, 44.5, 1, 44.5 1st Syncro 915-302-301-06, 63, 1, 63 2nd Syncro 915-302-301-04, 62, 1, 62 3,4,5 Syncro 911-302-301-06, 57, 3, 171 Dog Teeth 1st 915-302-241-14, 106, 1, 106 Dog Teeth 2nd 915-302-242-00 105, 1, 105 Dog Teeth 3,4,5 915-302-242-03, 105, 3, 315 Guide Sleeve (spyder) 1st-2nd 915-302-401-02, 118, 1, 118 Slider 1st/2nd 930-302-411-02, 143, 1, 143 2nd brake band assmbly Double Band Band 928-302-318-02, 29.71, 1, 29.71 Stop Block 915-302-315-01, 14.17, 1, 14.17 anchor block 2nd gear 928-302-322-00, 16.96, 1, 16.96 Parts Total 1230.34
84 Carrera All stock original paint (grand prix white), a beauty w/220k miles and still running strong. |
My grinding in 1st issues went away when I replaced the clutch. You have a 30 year old car and I bet the clutch is really old. People blame 915 transmission for being difficult but I think its old clutchs. The clutch takes almost no effort to push when new. If yours is hard to press it is old.
Get swepco 201, replace the shifter bushings and install a Seine shift kit ($150) and your shifting experience will be transformed.
Thermal reactors on an SC? I think those came w/the 2.7 not the 3.0. The problem w/the SC oil temperatures is this stupid trombone "oil cooler" which isn't really much of a cooler at all. A Carrera cooler w/fan is the way to go as far as fender mounted units go. W/o the fan the car will still overheat in traffic.
'82 SC pewter metallic Time and Relative Dimension(s) in Space |
Agreed on all the above, except (cynical me), I've got a carrera cooler + fan, and while it's much better, it's still not enough for track days.... But perfect for traffic jams !
I don't want to preach but if the tires are down to the wear bars be VERY careful when driving in the rain. When I bought my SC a few years ago I went on a short trip and it rained all the way back, I scared the heck out of myself even at moderate speeds. Ordered new shoes the next day. Enjoy
Bernie |
And the good news is my Targa doesn't seem to leak! ![]() W/o records, I have no idea if the clutch is original or if it's been replaced lately. The action is easy and the pedal feels light(ish) and comfortable. Other than that slight juddering issue (which I'm pretty convinced is operator error) I have no reason to believe it's not a good clutch. But you never know... ![]() I plan to move the cooling improvements up on the priority list. I don't know if the SC exhaust has thermal reactors like the 2.7 cars, but it does have a significant catalyst (3 way I believe) that looks to be creating a lot of heat. We don't have e-check anymore, so those will have to go. Then I'll look into the front cooler. Since this car won't see track action, I'm sure that's as far as I'll go. rburn - thanks for the detailed info! Still hoping to get the car to my wrench this coming week. I'm trying to drive it very little until then (with the bad tires and need of valve adjust). I'll have more info after the appt!
