oil level gauge problem
Hello all.While driving today my oil level gauge went to zero.The oil pressure is good and the dip stick is ok.Earlier today everything was fine.Could this be a sender problem? I hope that's all it is. Cheers
Kevin |
durn for'ner
Welcome !
As you know, the oil level gauge is only reliable idling on level ground and full operating temperature. While driving much oil is pumped from the tank into the engine - level gauge often down on red. Unless overfilled from the start of course. Hence, on the move the level will fluctuate a lot depending on acc / brake, turning etc. But usually shows very low readings. Of course if your gauge 'normally' show a higher reading and just at that described moment suddenly drop it could point to some kind of issue.
Markus Resident Fluffer Carrera '85 |
instantaneous sure sounds like a sender issue..unless you experienced catastrophic loss of oil, which would have become obvious rather quickly..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
or....it could be perfectly normal....you say "while driving"...what happens on level ground, at idle , at temp ??
- Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
This same thing happened to me years ago. Turned out to the be the sending unit.
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
mike and i are in agreement here..sure sounds like the sender. how would you respond to wil's questions though?
ryan
The gauge usually pops right to the top when the sender fails. I've just replaced my defective sender so I know first hand....
2007 Porsche 911 GT3 Club Sport, 1992 RUF RCT EVO, 1980 Porsche 911 SC Targa, 1978 Porsche 911 Turbo, 1968 Porsche 912, 1988 Ferrari Testarossa |
kevin..pull the gauge free in the cockpit and check your connections.
ryan
If it behaves properly during an "idle check...like you do when you check oil level properly...then all is fine...that is why I ask. As soon as you start driving, and RPM's pick up...it all goes into the red zone because of the difference in capacity between the pressure side and scavange side of the pump...
- Wil
oil gauge problem
Thanks for your answers.To answer Wil's question...at idle on level ground and at operating temp the gauge is around the centre normally.I hope to see my mechanic this morning .As a new Porsche owner it is a little disconcerting so hopefully everything is fine.I will let you know how I get on.Cheers
kevin,
at idle, level, op temp..the gauge should be at the top if it's full..at the middle you're probably running at least a quart low. ryan
Sounds perfectly normal if indeed the dip stick matches the mid gauge mark at warm idle....
....no problem.... this is how it works..... - Wil
Banned but not out, yet..
Check the wires connecting to the sender. They are prone to rust since they are exposed to water off the tire. Mine appeared to fail too but it was a rotted wire.
An air cooled refrigerator. ‘Mein Teil’ |
Brass Faston connectors and tabs are not likely to rust, but corrosion can cause a problem, or a wayward rock can fracture the wire under the insulation.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
RETIRED
Disconnect it and you won't have anymore worries. Probably the most worthless piece of equipment ever installed in a Porsche.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
durn for'ner
I would say the brake pad sensors take the prize...
Montana 911
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Just to clarify, Kevin, you are aware that the oil level gauge will indicate the level in the tank ONLY when the car is at idle, level and up to operating temperature, and it will read zero under any other conditions, correct? And the problem is that the gauge still reads zero even under the proper conditions now?
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
Won...exactly..
It seems that is what I was trying to say for a number of times now... I'm "...swingin' but the wood chips ain't flyn'..." as cartoon character Foghorn Leghorn sez..... ( for you old timers) ![]() PS- there has been no further confirmation that I can see that the gauge is reading incorrectly under any OTHER operating conditions..or did I miss that point ?? PPS- As to the gauge being worthless.. I vehemently disagree...it is telling you EXACTLY what is going on in the oil tank...the comings and goings as the mismatch between the scavenge and pressure pumps continues. You simply have to KNOW that for oil level readings, the car has to be on level ground, at idle RPM ( 800-900) and the oil temp warm ( 190 degF or so...8 o'clock position). - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 07-15-2006 at 06:58 AM.. |
RETIRED
Just an opinion Will.....as one who likes accurate assessments of what's going on, the wild fluctuation of the needle is a distraction.
Having made the decision to ignore it and simply check the oil at gasoline fillup time while scanning the "other" accurate gauges....my life is simpler....now, tell me how to handle three pre teen girls and my life would be complete.....
