-   -   Boosting 2.7 Performance (http://forums.pelicanparts.com/porsche-911-technical-forum/29343-boosting-2-7-performance.html)
NJJim 12-19-1999 08:52 AM
I'm in the process of having my 2.7 rebuilt Everything I've read so far states that CIS Fuel injection is basicly bullet proof, but that carbs are the only way to acheive a substancial HP gain above that achieved by backdating the exhaust.
The engine is torn down and I'm debating between a standard "stock" rebuild" or going more agressive: cams, head porting, carbs. ect. This car won't be an everyday driver...but isn't intended to be a pure track car either. Would moving away from CIS be a mistake regarding reliability ? Are there aftermarket fuel injections systems in the 2K price range that would offer me the same HP benifits ? I've considered upgrading to a 3.0 or 3.2, but i felt i could build my 2.7 to meet or exceed the HP of these engines for the same $$...or less. then buying a $4500 used 3.0 or 3.2 and be faced with a rebuild anyway.
Any insight is appreciated !
stlrj 12-20-1999 07:14 AM
Pick up a copy of "911 Performance" by Bruce Andersen. He has a lot of experience in that arena.
Craig 12-20-1999 11:55 AM
NJJim,
Nothing to add, but I would like to know what you decide, as I have a 2.7 I am going to rebuild this coming spring (I need the garage right now). I too am looking for ways to boost performance, without modifying the engine too much (bolt on hp..)
Keep me posted, and good luck with your rebuild!
Craig (cperry@waterpik.com)
NJJim 12-20-1999 01:46 PM
I have read through Bruce Anderson's suggestions. He's pretty clear on getting back to carbs for true performance on the 2.7. I just thought their might be a fuel injection system out there that would provide the same type advantages while not blowing the chance of me ever passing emmisions again !
Craig, I'll let you know the end result regarding HP.
Jim
mikez 12-20-1999 01:52 PM
Don't add carbs without modifying the cam profile.... http://www.webcaminc.com/
These guys make regrinds for 2.7s and have many different profiles. Pelican sells new ones. I used the 964 cams on my 3.0...but kept the CIS.
Brian B 12-20-1999 07:42 PM
Webers will improve throttle responce but give away fuel mileage and reliability. They also run more rich than CIS so passing a smog test would be tough. If you live in the midwest you have to tune them seasonally. Other than SSIs there isn't much out there for < $2000 that will significantly increase HP, believe me I've looked hard. mikez - regarding the 3.0L CIS with 964 Webcams, how much did this help? I have been entertaining the idea of a cam swap.
