-   -   MFi Gurus (http://forums.pelicanparts.com/porsche-911-technical-forum/293614-mfi-gurus.html)
nigel911 07-15-2006 06:29 PM
MFi Gurus
I have an issue with my car - I'm guessing it's the MFi but I don't know for sure. After a run on the interstate I came off onto a minor road, the lights were red so I pulled the car up - rather than dropping to idle the engine just faltered and died. Started straight back up upon the turn of the key. This happened a couple of times today, both times after a period of the engine running at a higher constant speed. What would cause this?
I have a new muffler on the car - could this have anything to do with it?
Grady Clay 07-15-2006 07:26 PM
Nigal,
What year MFI?
The symptoms you describe are characteristic of a partially blocked filter screen at the fuel tank. This is usually from rust and debris in the fuel tank. There is a lot in Pelican archives about this.
Any other symptoms?
Best,
Grady
nigel911 07-16-2006 08:30 AM
Grady, the Mfi is the original unit from the 72. The PO had the MFi rebuilt, without wanting to tempt fate it has always worked 100% perfectly. Kind of happy the issue may not be the MFi unit.
Will search the threads on the tank filter screen issue. I'm assuming it is only affected after a high speed run because the car is 'sucking' greater amount of fuel (debris) through/against the filter?
How big a job is the tank filter screen?
Many thanks for your help.
