-   -   How do I get under a 964? (http://forums.pelicanparts.com/porsche-911-technical-forum/293770-how-do-i-get-under-964-a.html)
SLO-BOB 07-16-2006 08:01 PM
I like to throw the comedians an easy one now and then, but the question remains...
I need to jack up the soon to be mine 964 and place it on jackstands in back. I did a search and found that lifting by the motor is inadvisable. The jackstand points are the same as the jack points so how to do this? Any help is appreciated.
Steve@Rennsport 07-16-2006 10:17 PM
Hi Bob:
I've refrained from lifting these cars equipped with the hydraulic motor mounts, by the engine unless they were converted to the RS rubber ones.
Use a floorjack positioned under the suspension pickup points.
LeRoux Strydom 07-17-2006 02:24 AM
Jack up the car using one of the rear jackpoints on one side first. Lift the car high enough to get a jackstand underneath the front jackpoint. Do the same on the other side. Then jack up the rear of the car using the engine/gearbox joint, and position jackstands underneath the rear jackpoints. Reverse the procedure to get the car down again.
I have jacked up my car endless times from underneath the engine with no ill effects.
