-   -   What is the best way to increase brightness in gauges? (http://forums.pelicanparts.com/porsche-911-technical-forum/294027-what-best-way-increase-brightness-gauges.html)
Mysterytrain 07-20-2006 06:03 AM
I replaced my bulbs and the results were nothing to write home about. I then replaced them with LED's. The results were slightly better. I've read that adding headlight relays can help the dash light circuit but I can't verify that. The trouble with the LED's is that they don't have that 'old school' yellow light look nor do they have the wide spread that the bulbs had. They give off a much whiter light but produce hot spots. The best solution appears to be the big bucks NH speedo conversion but I have never seen what that looks like with the stock black faced gauges. If you do some poking around on the net you will see that the bikers and blingers are using some flexible, low profile LED strips on their vehicles. I'm betting that this is what NH Speedo is doing with the gauges because the flexible string off LED's can be wraped around the gauge case and eliminate the hot spot. I would be interested in seeing how they apply power to the gauge?
Miguel Antonett 07-22-2006 12:39 PM
HELP!
I tried to pull the red looking plug - where the cable goes trough - and could not get it out.
What should I pull straight out, the red plug only or the entire cylinder that holds the red plug?
Miguel Antonett 07-23-2006 11:14 AM
bump!
rouxroux 07-23-2006 11:43 AM
Miguel, be very careful and pry the metal collar up that surrounds the "red plug"...the entire lighting unit will come out easily as one assembly. Best of luck with your project.
Ron McAtee 07-24-2006 05:55 PM
I put in a "Mark Sucro" relay kit when I did the changeover to H4's and that alone significantly increased the candlepower of my instruments. Seems to pass more power through to the lights than through the stalk switch. I'm sure that if I put new bulbs in there, it would also brighten them up. Mine are quite adequate now with the relay kit.
Chris Lovell 07-25-2006 06:12 PM
I would be interested in how this LED "dash bling" upgrade might be accomplished, and what parts would be needed. It sounds like a decent and meaningful weekend project which will be rewarding.
Any thoughts you electrical gurus?
quattrorunner 07-25-2006 06:24 PM
Slant nose, you have a PM
holtjv 07-26-2006 09:31 AM
Originally posted by Miguel Antonett
bump!
I used one of those little flathead screwdrivers to get it started, prying under the metal ring. Then I switched to a bigger blade flat head and twisted to get it up. J
Early_S_Man 07-26-2006 09:39 AM
<b>Guys, if you are having to use tools to pry to get the bulb holders out ... THAT SHOULD BE A BIG CLUE TO YOU that the bulb holders need cleaning and polishing!!! Ask you self WHY they are stuck??? Corrosion, that's why!</b>
Only the alternator warning lamp bulb is the larger #1816 style bulb! All of the illumination bulbs are BA7-base bulbs, 2 Watt.
84porsche 07-26-2006 10:25 AM
Originally posted by qlander
LED and white faces NH speedo. Expensive but worth it.
BEAUTIFUL - Can you post how much this cost? It might be something worth saving for.
SlantnoseSD 07-26-2006 10:27 AM
I think he said $700
Early_S_Man 07-26-2006 12:49 PM
I'm not sure why two guys had to repost the pic of those <b>Horrid white-faced gauges,</b> as those look like they are perfect for (and a copy of) an eBay Gemballa custom-built for some present/former media 'star' with questionable taste and intelligence! Pure, outragious, ricer-style, attention-seeking appearance, and fully capable of completely destroying your night vision! It could only be worse if the illumination was BLUE!
Dan in Pasadena 07-26-2006 12:56 PM
...Not that you have a definite opinion or anything:rolleyes: :D :D
84porsche 07-26-2006 01:02 PM
I am not a fan of the white face but more a fan of the lighting quality. I would be interested to see a better illuminated black face gauge. We already have Porsches, how much more attention seeking would white gauges add. It is a personal preference, some like it, some don't. Speaking of blue, it looks quite cool in a modern day VW so much so that many manufacturers are copying them. - http://forums.vwvortex.com/zerothread?cmd=print&id=2437133
http://forums.pelicanparts.com/uploa...1153944102.jpg
Mysterytrain 07-27-2006 07:54 AM
As an old school sports car fan I have to admit that before I owned my 911 I once owned a 62 twin cam MGA. I always liked the the dimly lit gauges on the MG but I was 21 at the time. When I stepped up to the Porsche I was pleasantly surprised at how modern and bright the 78SC guages were...well, that was back in 85 and I was 37. Same car, same owner but my eyes seem to want more light for just about anything I do these days. If I drove the 911 everyday and more often at night I think I would spring for the NH mod on BLACKFACE gauges. ;) In the meantime I'm still exploring those flexible LED strips. Can any of you guys that have gone down this road post a picture of the rear of the gauge showing the electrical connection?
Miguel Antonett 07-27-2006 08:03 AM
I'm with you Mysterytrain. I have my car for 25 years and somehow the dash lights are going away... :-)
safe 07-27-2006 11:45 AM
+1
Original poster: You are aware that you can dim the gauge lights by turning the headlight switch?
If not check if it's on max.
tonypeoni 09-16-2006 02:30 PM
I recently tried this led swap. This is what I ended up with maybe I did something wrong. I think leds need a stronger current to work properly.http://forums.pelicanparts.com/uploa...1158442172.jpg http://forums.pelicanparts.com/uploa...1158442223.jpg
tonypeoni 09-16-2006 02:32 PM
BTW these are the super bright white leds from Super Bright Leds .com.
RoninLB 09-17-2006 05:24 AM
I never investigated LED's as other pelicanheads have so only a wild guess that the special glow paint on the gauges is old and worn?
