Guest
Posts: n/a
Can CIS be used on an MFI motor
Can CIS injection be used in place of
MFI. Are the cams pistons and other engine componets diffrent enough that this conversion could not be done on a 2.2E motor. |
Guest
Posts: n/a
Not very well. The cam shaft lift and duration will cause a intake pulse wave that will make the sensor plate osolate. This condition will create flat spots and idle problems. You best convert to Webers.
Good Luck, Lee |
