-   -   Window regulator pivot pin (http://forums.pelicanparts.com/porsche-911-technical-forum/294523-window-regulator-pivot-pin.html)
Gearbox 07-20-2006 03:02 PM
Anyone know if the pivot pin for the window regulator spring is available anywhere? This is the aluminum pin that is peened into one of the window regulator arms and hinges 2 others finally holding onto the center of the regualtor spring. This one is from my 1971 911S. I could lathe one out, but rather buy one if available. Thanks Allanhttp://forums.pelicanparts.com/uploa...1153432931.jpg
joehahn 07-20-2006 04:31 PM
a HA! I knew someone would need one of these...PM me, I have a new one and the spring thing and I don't have a Porsche anymore so we have a good fit.
pics here: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/293112-65-68-other-years-parts-spark-plug-tool-window-crank.html
Joe
Gearbox 07-20-2006 04:53 PM
Email me with your number, I just sent you a PM, Thanks Allan Gearbox@Comcast.net
HarryD 07-21-2006 12:01 AM
Gearbox,
Be aware that these pins come in 4 flavors. Be sure you are getting the correct one. The pin joehahn shows has the the spring slot perpendicular to the rectangular (key) end but your pin has the slot parallel to the rectangle. They also come in two lengths.
You can see the sizes at Performance Parts (sorry Wayne but I do not see these on your on-catalog even thoughyou can get them if ordered).
Nine9six 07-21-2006 06:56 AM
Good eye, HarryD
