Window regulator pivot pin
Anyone know if the pivot pin for the window regulator spring is available anywhere? This is the aluminum pin that is peened into one of the window regulator arms and hinges 2 others finally holding onto the center of the regualtor spring. This one is from my 1971 911S. I could lathe one out, but rather buy one if available. Thanks Allan
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S. www.TheLolaRegistry.com "When you think you are in full control, you're just not going fast enough." |
a HA! I knew someone would need one of these...PM me, I have a new one and the spring thing and I don't have a Porsche anymore so we have a good fit.
pics here: 65-68 (and other years) parts. Spark plug tool, window crank, Joe |
Email me with your number, I just sent you a PM, Thanks Allan Gearbox@Comcast.net
Gearbox,
Be aware that these pins come in 4 flavors. Be sure you are getting the correct one. The pin joehahn shows has the the spring slot perpendicular to the rectangular (key) end but your pin has the slot parallel to the rectangle. They also come in two lengths. You can see the sizes at Performance Parts (sorry Wayne but I do not see these on your on-catalog even thoughyou can get them if ordered).
Good eye, HarryD
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
