rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Question Dumb (probably) question about deck lid struts
I recently ordered a new strut for my deck lid. After attaching it to the firewall I was unable to get it to mount to the lid because I couldn't get the strut shaft to move in or out. I told the seller it was defective and I just received the new one. I can't get this one to move in or out either. Am I missing something (mentally)?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 07-21-2006, 08:51 AM
As I recall (it's been a long time) the new struts are quite stiff compared the old, limp ones you are replacing. If you press real hard you can compress them as necessay for installation. Certainly, they should require slight compression, not extention.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 07-21-2006, 09:04 AM
These are almost impossible to compress by hand...they need the mechanical leverage of the installed position to allow them to compress.
normally...if you can't get them to fit....try fitting one end on the firewall and the other end is "loose". Then... if it doesn't want to fit the deck lid attachment point...you may have to lift the lid slighty to allow the "eye" of the strut end to fit.
I say "normally"....
My latest set was a Weltmeister Lifetime HD set....and the eye-to-eye length was way off...almost one entire "hole" diameter longer than stock ! Had to unscrew the end fitting ( it's pot metal) ..and sawed off a bit of length...and then re-installed ( simply screwed back on)....NOW I could get it to fit both ends. The extra length was most certainly wrong compared to the "extended" length of the factory part.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-21-2006, 09:30 AM
Virginia Rocks!
VaSteve's Avatar
Yes, lift with you head and slip the pin in.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 07-21-2006, 10:09 AM
defcon65's Avatar
I had the same experience with my new strut from Pelican and I was able to compress it using a quick-clamp. You could also try to compress it with a long lever, like a 2x4 wedged under something unmoveable and pressed downward. I thought for sure that it was so stiff it would bend the strut mounts when I tried to close the lid, but the mechanical advantage of the lid and mounts compressed it easily. Now I don't have to use a chunk of broomstick to hold open the lid!
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 07-21-2006, 01:00 PM
"Now I don't have to use a chunk of broomstick to hold open the lid!"
Yep. Broomsticks seem so inappropriate for a 911. So are struts that last only 6 month. There is another solution.
Sherwood
www.seinesystems.com
unabashed adv.
(This are available from our host, btw)
Old 07-21-2006, 01:15 PM
defcon65's Avatar
Yeah, I noticed my 'old' strut looked pretty freakin' new when I took it out, and I've seen your elegant solution as well, Sherwood. I think there's a kit for installing a second strut back there, but I'm not sure what is involved. Happily, I have a 3.2 Carrera and hardly ever open the deck lid except to prove to disbelievers that the engine is really in the back.
Joe
Joe
Joe
85 Carrera
Old 07-21-2006, 01:36 PM
rs6er's Avatar
Yes. The top of my head worked great! Now if I had only used it in the first place. LOL
John
Old 07-21-2006, 01:37 PM
