carrera intake to 3.0
Ok in the search for a little more free flowing intake I just bought a carrera intake for my 3.0 turbo. What will I need to do to bolt it up?? Anythoughts?? I searched and saw some reference but not much. What do you guys think??
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 07-20-2006, 08:51 PM
bump
Ben
89 944,85.5 944
914-6werkshop.com
Old 07-21-2006, 08:33 AM
TOO RUF's Avatar
No it does not just bolt up. You need the plastic spacers, new studs for heads. Then you must enlarge the intake at the injector opening on the head for it spray properly. Then you can add a little aluminum to the head for a larger gasket seat. I skipped that part and it still worked.
15 Cayman
93 Amethyst 964 Cab & 67 21 window VW Wife's
64 356
69 912 targa
68 911L Hot Rod
Old 07-21-2006, 08:46 AM
So the head port is a bit small??
Ben
89 944,85.5 944
914-6werkshop.com
Old 07-21-2006, 09:01 AM
TOO RUF's Avatar
Yes, Buy the plastic spacers and you can mark it out exactly where you need it. I also had to use the stock gaskets from the 3.0 and use a hole punch to modify them to fit.
15 Cayman
64 356
69 912 targa
68 911L Hot Rod
Old 07-21-2006, 09:06 AM
What Length intake studs?? I looked on the pelican page and found no reference to 84-89 carrera head to intake studs
Ben
89 944,85.5 944
914-6werkshop.com
Old 07-21-2006, 09:12 AM
TOO RUF's Avatar
I don't remember. I called Pelican and we ordered the longer of the two that they supply. I think it is the same as the exhaust studs for the same year carrera.
15 Cayman
64 356
69 912 targa
68 911L Hot Rod
Old 07-21-2006, 09:21 AM
goldgunner's Avatar
I did this as well.
I took the easy route and had Walt at Competition Engineering modify the injector ports and match the manifold ID's to the 3.0 head intakes - that is necessary. You will, as noted, need the thick phenolic spacers and gaskets on both sides of that.
Walt convinced me that adding a weld bead to fill out was unnecssary - and I'm thinking he's correct.
Regards,
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 07-21-2006, 12:16 PM
The reason for this is I feel the cis system is a bottle neck for my turbo system and would like to get maximum boost early on. We will see
Ben
89 944,85.5 944
914-6werkshop.com
Old 07-21-2006, 01:27 PM
