126coupe's Avatar
Sources for steel fuel lines
I am revamping the fuel system in my 911 race car (carbs)
What is a good source for steel fuel lines?
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 07-22-2006, 08:04 AM
Slumlord
Porsche_monkey's Avatar
Why not use hydraulic steel tube and JIC flare fittings? Cheap, relaible, easy to bend, and pressure rated.
Look in the yellow pages for a hydraulic supply house.
Old 07-22-2006, 08:28 AM
Europa Auto's Avatar
Do you have a picture of the fuel lines you want to replace? I might be able to help you.
Mike
2002 996 911 Carrera Cab
1998 Boxster S
2002 BMW X5
1978 FJ40 Land Cruiser
2005 Jeep Liberty CRD - Diesel
www.europautoparts.com
Old 07-22-2006, 08:36 AM
126coupe's Avatar
I am not replacing any hard lines only adding one from the rear of the car to the front
28' Pace Trailer
Old 07-22-2006, 09:15 AM
the fuel inlet and return "hard" lines exit the tunnel in my car with a coupling to rubber lines. I disconnected the 2 rubber line couplings and brought them + hoses to a hose shop. They used the couplings on 2 ss 6AN hoses.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-22-2006, 09:38 AM
126coupe's Avatar
Does anyone know the id/od for porsche steel fuel lines.
I did a search no luck
28' Pace Trailer
Old 07-22-2006, 10:05 AM
Slumlord
I believe you need 3/8" supply, 1/4" return.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 07-24-2006, 05:46 AM
Some wanted info may be these threads
68 911 Fuel System
3.2 Carrera engine swap: fuel system changes
Also it may have been member Jim Sims that posted a list of fuel lines ID & OD at one time.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-24-2006, 11:03 AM
Classic's Avatar
Eastwood sell 5/16 brake line which is a match for the fuel line on my 69
http://www.eastwoodco.com/jump.jsp?itemID=2478&itemType=PRODUCT
Classic 1969 911T
Old 07-24-2006, 02:39 PM
DW SD's Avatar
Pressure line is nearly 5/16", which is a common hardline fuel line size. Porsche factory used 8mm OD on many early cars. I revamped my fuel system like this: AN fuel fittings for fuel system 8mm ~ 5/16th"
As you'll see in that thread, 8mm is VERY close to 5/16".
I'd order 5/16" hard line in bulk from Summit. I think you can buy Stainless or mild steel or AL.
Doug
1971 RSR - interpretation
Old 07-24-2006, 03:48 PM
