shifter mods?
i want a more mechanical direct feel at my shifter (91 964). is there an aftermarket shifter avail or a way to modify my shifter with metal bushings etc.
best is to use the factory RS parts
There are 3 parts different from normal that the factory used for the 964 and 993 RS shift mechanism 964.424.015.08 lever 964.424.017.01 fork 964.424.020.35 rod the same pieces are used on 964 5 speed and 993 6 speed transmissions. As w/ the 911 equivalents shorter throws and less slop are the benefits.
are there non metal parts in these mechanisms...as in bushings or couplings
The only rubber even in the stock ones is at the tranmission end of the rod. The RS replaces that w/ a solid fitting
Here are some pics originally posted by Geoffrey on Rennlist RS rod on the bottom ![]() RS lever and fork on left
that's perfect...shortens up the throw too. thanks very much for the info. i hope these are still available
You can also replace the bushing in the coupler with a 914 bushing. It's still plastic, but it is round instead of oval. I basically becomes a wevo coupler for about 10% of the price. There is NO slop and feels like a gate shifter.
I had to have mine pressed in for about $10.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please ![]() Chad aka "Chili" 1974 Base coupe in Carrera outfit. No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.) My car http://www.pelicanparts.com/gallery/CHILI 1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras. |
with the rs mods, will the shifter still fit in the tunnel? i recall something about an issue but i don't remember the details
C4 will have a minor space issue in the tunnel, C2 no problem
You are probably getting carpal tunnel from typing this very same info so many times! I, for one, appreciate your patience. That said, I understand your preference is for the above kit. I have a query in at my local Porsche dealership for price and availability. In the meantime, what are your thoughts on the Weltmeister kit? Looks to be a similar concept to the RS kit and it costs about $250. I have no idea what the factory parts will cost. I'm sure my PCA discount will knock it down next to nothing.
Never used the Welt but rumor has it those that have are not the happiest.
The factory parts are getting to be extremely expensive, the shift lever and fork are reasonable but the rod was cloing in on $500 last I heard. Do the fork lever and hope that someone(Wevo?) comes up w/ a reasonable priced coupler for the end of a stock rod, it should be easily doable. if anyone buys the rod be sure to get the bolt that goes w/ it, the bolt is not the same as the stock one. 999.074.042.02 M8x21.5 fitted bolt N.011.654.5 washer is generic
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Dealer pricing as follows-
57.45-lever (in stock) 57.45-fork (in stock) 423.53-rod (German stock-3-5 weeks eta) I didn't ask if the pca discount applies to these items. |
