Installing Mech. Brake Light Switch Quest.
Hello:
'79 SC Installing mechanical brake light switch per great write-ups found on search... One quick question: I am able to verify that the switches at the master cyl don't work, but I only get one of the brake lights to work when 'by-passing' the connection. Question is this: Do both lights work off same switch? I assume they do. I did replace bulbs and clean the contacts at the rear end... Any ideas? Thanks! Eric |
Anyone?
Eric,
Yes, both brake light wires are tied together ... looks like it would be between the two 6-pin connectors in the engine compartment ... Green/Yellow wire. http://www.pelicanparts.com/911/911_...SC_Part3-1.jpg |
Thanks much!
Eric |
| All times are GMT -8. The time now is 12:39 AM. |
