Hello:
'79 SC Installing mechanical brake light switch per great write-ups found on search... One quick question: I am able to verify that the switches at the master cyl don't work, but I only get one of the brake lights to work when 'by-passing' the connection. Question is this: Do both lights work off same switch? I assume they do. I did replace bulbs and clean the contacts at the rear end... Any ideas? Thanks! Eric
'79 SC Silver over Black... Sold |
Anyone?
Eric,
Yes, both brake light wires are tied together ... looks like it would be between the two 6-pin connectors in the engine compartment ... Green/Yellow wire.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks much!
Eric
