Yellowbird RS's Avatar
Please tell me what front shock absorver do I have
they are black in color and my struts are for M calipers w/3" between bolts
X/A
Old 07-24-2006, 01:44 PM
Friend of Warren
Well the housings are boge. The inserts could be anything. Have to pull them to find out.
Kurt V
Old 07-24-2006, 01:47 PM
So I can use anyone in my current housing
X/A
Old 07-24-2006, 07:21 PM
930turbo's Avatar
You can use many, just be sure to specify Boge strut housings. Not all manufacturers build to fit this application.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 07-24-2006, 07:27 PM
LakeCleElum's Avatar
Sounds like you have Boges.....Put in the Bilstein Insert - I did a love it......
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 07-24-2006, 08:08 PM
TWork's Avatar
Kurt, how do you tell what type the housings are? Is there something in particular in the photo that distinguishes them as Boge?
'73 Targa
Old 07-24-2006, 08:36 PM
you see Arthur...
jasonlee's Avatar
Boge housings were black and Bilsteins were green. I think Konis were yellow. Someone please correct me if I am worng.
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 07-24-2006, 08:48 PM
You are 100% right, after a little research I found the color chart for the different shocks
about the Koni I need the 86-1647 and looks like PP have it in stock.
thaks!
X/A
Old 07-24-2006, 09:45 PM
Early_S_Man's Avatar
Porsche Crest
Considering the age of the vehicle, and that the struts may have been painted over ... the only way to be sure is to clean the lower strut housing and find the Porsche OEM part number or mfr stamp. Either 'Boge' or 'Koni' will be stamped into the strut housing tubing. Boges were originally painted black, and Konis were painted red-orange.
Koni still makes inserts for '72 - '74 Boge struts ... pn #8641-1039.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-24-2006, 09:49 PM
