rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
It's too hot out! Winter question.
In cool temperatures my AAR takes forever for the RPMs to drop from about 1800-2000 RPM. I can drive for 10 min and the revs still stay up. Ususally if I shut it off and start again a little later the idle will drop down. My mechanic confirmed that the AAR is not working properly. Having priced a new one--astronomical!-- is there any way to fix the one I have?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 07-28-2006, 03:58 PM
Designer King
Paulporsche's Avatar
Search AAR and Mystery Train. He has a great thread on repairing/tuning the AAR.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-28-2006, 08:30 PM
Hey, Paul..rs6er..You should check for 12 volts at the connector that plugs into the AAR and also check that you have 17 to 27 ohms [top of my head with those values] on the heating element. You can measure that from the two terminals on the AAR. The AAR needs to have the heating element powered to get the bi metal strips to close the opening. The engine heat isn't always enough and will cause it to drop the idle very slowly.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 07-29-2006, 09:58 AM
rs6er's Avatar
Thanks guys.
John
Old 07-29-2006, 02:03 PM
