cameron.arnott's Avatar
Weird Engine Stutter
Help Please!
When I'm driving the car and just maintaining a constant speed or using very low throttle pressure the car stutters and hiccups quite badly, no problem once you start to apply enough throttle to make the car accelerate.
I've recently replaced the leads with Magnecors, had the distributor rebuilt and recurved and added a Pertronix, had the Webers apart, cleaned & rebuilt, replaced the coil.
The car is a '71T running a 2.4 S motor with 2.2 S pistons & Webers. The problem seemed to start a while after the Webers were apart....
Any ideas what the cause could be?
'74 RS 3.0 Replica
Porsche 968 Clubsport SOLD
'70 911E Bahia Red SOLD
'71 911 S/T Replica 2.3 Twin plug BEAST SOLD
Old 07-27-2006, 08:23 PM
I should add the the distributor cap is new and the NGK BP8ES plugs only have a couple of hours on them...
'74 RS 3.0 Replica
Old 07-27-2006, 09:50 PM
With Webers I would try hotter plugs to see if they help. try bp7es. I know the PMO guys recommend BP5es for carbed Porsches. Depends on your compression ratio. I'd go slow. Don't want to burn a hole in those pistons. Good Luck.
69 911 2.3Ez
85 928S
Old 07-28-2006, 10:14 AM
defcon65's Avatar
Are you convinced it's ignition related and not a carb problem? I'm no expert on carbs, but it sounds more like a fuel delivery problem at specific rpms and not an ignition fault or incorrect heat range on the plugs.
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 07-28-2006, 01:09 PM
keitho64's Avatar
Cameron
I am having the same problem. I think in my case it is due to worn throttle shafts. I am curious to see if yours are the same.
I have a 71 2.2 s motor, 55 idle jets, 130 main, 180 a/c, f1 tubes and 32mm venturries.
Check out this thread.
Weber Idle Air Bleed adjustment opinions
Do you have much play on the throttle shafts?
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 07-28-2006, 03:13 PM
Thanks Guys
I dd put some BP7ES plugs back in yesterday but haven't had the chance to drive the car. I also blew out the idle jets but that had no effect.
The throttle shafts seem ok but I will be pulling the carbs out in another week or so when I have more time to look at them more closely.
I'll keep you posted on progress...!
'74 RS 3.0 Replica
Old 07-28-2006, 03:44 PM
