Question You use an OBD II reader??
Also posted on the 993 forum.....
I'm thinking about getting an OBD II reader so that I can maybe know a little more about what's going on if I get a CEL or other message on my 993's dash.
Do you use one? What kind? Happy with it? What do you do with the info once you see what's going on? Do you attack the problem yourself if it's a simple fix, or just use the info to make you more knowledgeable when you talk to a technician?
The price range is wide, and Wayne recommends a unit that works with your laptop. Can you take the info and load it later to a desktop PC, or does it need the laptop running to do the scan?
Any opinions welcome!
Paul
Paul
'87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff.
'96 993 cab (gone, oops); '82 SC (gone)
Old 07-28-2006, 02:58 PM
keitho64's Avatar
Paul
I got mine form www.obd-2.com and have been very happy with it. Mine works on all 96 and newer cars. Alex does update the program on a regular basis.
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 07-28-2006, 03:19 PM
Navin Johnson
TimT's Avatar
I have had an Autotap for years
http://www.autotap.com/
Works well, no affiliation, etc.
'69 911 GT-5
'75 914 GT-3
and others
Old 07-28-2006, 04:03 PM
Now in 993 land ...
aigel's Avatar
I got mine at the local parts store only to find it at Walmart later for almost half price! I would go with the bare bone basic unit. It will give you a code and you can take it from there.
There are true scanners that actually do a lot more, but they are not required for the basic maintenance.
George
81 SC (sold)
Old 07-28-2006, 04:13 PM
I've got one from scantool.net, you need a laptop and software to use it.
It will give you realtime readings of most of your sensors. Will also store various faults. On my wife's car is said one of the O2 sensors was responding too slowly and that the spark plug for cylinder number 3 was mis-firing. Also lets you reset the engine check light.
I'm about 20 minutes west of Richmond and would let you try it, but the connection where it plugs into the car is likely different, mine fits FORD products.
Good Luck
Mac
Old 07-28-2006, 04:37 PM
Now in 993 land ...
aigel's Avatar
OBDII plugs are all the same. It is standardized. George
81 SC (sold)
Old 07-28-2006, 04:55 PM
driver
porcupine911's Avatar
VAG-COM
since you also have an audi...
http://www.ross-tech.com/vag-com/index.html
i am a happy customer. it is designed for VW AG products but also contains generic OBD II functionality.
- chris
Street: 1971 911E, 2007 GTI 2.0T, 2012 Cayenne Turbo, 2019 GTI TCR, 2022 Boxster 25 years
Circuit: 2020 Cayman GT4
Old 07-28-2006, 06:37 PM
I have an Antron. Works fine on the Volvo and BMW. Got it directly from the manufacturer and I like it.
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 07-28-2006, 06:46 PM
Let me know if you want to give it a try.
Mac
Old 07-28-2006, 07:07 PM
I bought an Antron CP9135 tonite...let's see what it does. My 993's been doing the CEL thing; a low voltage issue according to dealer; new battery (free) but came on again later. Time to get involved.
Paul
Paul
Old 07-28-2006, 07:16 PM
