-   -   Oxygen sensor too short after SSI install (http://forums.pelicanparts.com/porsche-911-technical-forum/295986-oxygen-sensor-too-short-after-ssi-install.html)
rs6er 08-01-2006 08:33 AM
Here you go. BTW. Got the muffler and exchangers together last night. Muffler went on beautifully. Since it was 1 AM. I thought I'd wait till today (after work) to put the oil back in and listen to the music?
http://forums.pelicanparts.com/uploa...1154444957.jpg
http://forums.pelicanparts.com/uploa...1154446173.jpg
mb911 08-01-2006 09:44 AM
Ok so if you clip the existing wire clean with the Original O2 with a new one being 6 inches will it work then??
rs6er 08-01-2006 10:04 AM
I'm not sure what you're saying. I think you are asking if I cut the wire off the original sensor right at the sensor and got a new sensor with 6 inches of wire to replace the original, I could then splice the new sensor's wire to what's left of the old one and it would reach. Actually, I'd need 8-9". The Bosch part mentioned above comes with only about 2 1/2" of wire though. There is a $30 Bosch sensor with a longer wire and a female spade connector at the end of the wire that I could use if I attach a male spade connector to my existing wire (or cut the connector off and use a butt connector or solder), but I hate to pay $30 for a few inches of wire, since my factory sensor is pretty new.
mb911 08-01-2006 10:15 AM
yeah thats what I was thinking. I think that you could probably find that wire locally maybe even radio shack but you would have 2 butt splices which is not good for resistance
rs6er 08-01-2006 10:50 AM
Does it have to be a Bosch sensor? Also, did the 74 exchangers have a sensor?
mb911 08-01-2006 12:05 PM
no and no I would guess you would be fine with what ever you can find
