AC Compressor spitting grease...
85 911 with factory air set-up.
Whenever I run the AC, I find a streak of grease on the underside of the engine lid. I presume it's worn, but is this something that can be 'rebuilt' and repaired or do I need to replace the entire compressor?... Thanks, Ken
Ken 06 Cayman S - gone 85 911 Targa - gone back home to Germany 73.5 911T Targa - long gone... Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs |
Detached Member
You can get it rebuilt, probably easier and doing it yourself if you don't have the right pullers and such. If its the original York, why not get a new Sanden Seiko? You'll have to pull a vacuum and recharge with R-12 unless your converting to R-134. You have to have an EPA license for R-12.
Hugh |
Replace with a new seal. Might also need a sleeve to prevent the shaft threads from tearing the seal when installing it.
A more efficient compressor would be nice too. Sherwood |
Thanks for the info! Gotta love this site!
k
Used Up User
When it throws oil like that it is the shaft seal. See the write-up in the tech section on rebuilding. $30 worth of seals. I have the seals but haven't gotten to mine yet, but it does look reasonably easy.
see AC Kits for seals. Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
