shift coupler
replacing the shift coupler bushings....wondering if i need a press to push out the pin or do you guys just hammer it out?
thanks
Old 07-30-2006, 01:12 PM
I'm with Bill
Rick V's Avatar
Do a search, there have been several threads about this and there are several difering opinions on the best way to do them. Don't use a hammer!
Old 07-30-2006, 01:15 PM
hkspwrsche's Avatar
Dont use a hammer? no wonder nothing ever fits!
Actually, I used a bench vise as a press with a few diff sockets the last few times I had to do the coupler bushings. A hammer might shatter the whole works!
Good luck
Harold
Old 07-30-2006, 01:19 PM
Now in 993 land ...
aigel's Avatar
If you are challenged, you can buy the whole coupler, assembled, as well. I second the vise / socket procedure. Don't forget to add some motion lotion.
George
81 SC (sold)
Old 07-30-2006, 04:19 PM
im sure no one will guess nor approve of the way i finally got the coupler apart.
i got to the point where i didn't care anymore and if i did break it i could just buy a new one.
i didn't have a vise.
don't use a hammer? howabout an air hammer??? put the whole coupler on a piece of wood with a 1/2 inch hole drilled through it. put the air hammer to a small nut and placed it on top of the pin to be pushed out. 10 seconds of the air hammer and its gone.
shifting is better, but still a little loose...must be the forks all worn out inside the transmission...
david
Old 07-30-2006, 05:11 PM
Oh Haha's Avatar
The slop may not be the forks in the tranny. The factory coupler bushings have some slop built into them to take up some of the vibrations. The 914 coupler bushings or even brass are supposed to be a better option.
Did you replace the other bushings associated with the shifter?
Pacific Blue
Wayne
Old 07-30-2006, 05:40 PM
DarinB's Avatar
I used a hammer and a punch to get the pin in and out. I just placed the coupler on a socket that was smaller than the coupler itself so the impact was distributed to the bushing instead of the aluminum of the coupler. In and out very easily.
Darin
1995 993 - Black/black, RS splitters, brake ducts
1978 SC - "Toyo Spec" - Completed
Old 07-30-2006, 07:16 PM
Wayne,
I did replace all the shfit bushings...the two up front by the shifter, and then the two in the shift coupler. When the tranny is in first gear, I can move the shifter side to side maybe like 3/4 of inch and i can see the whole shift rod, coupler and all move...there's definitely something inside the transmission moving....
Old 07-31-2006, 10:34 AM
Oh Haha's Avatar
I am not with my car right now but I think there IS some play in the shift rod INSIDE the trans.
You know these will never be as nice as a modern setup, right? i ahve some slop inthe shift block myself. I am working on a solution to this problem right now with a spacer/pin setup. I am not trying to out-emgineer the Porsche guys but modify to meet my needs.
Pacific Blue
Wayne
Old 07-31-2006, 01:46 PM
Now in 993 land ...
aigel's Avatar
Absolutely. People tend to forget this. In the end you just have to get used to your transmission. I could shift my 915 as well as I can shift the G50. Same is true for my wife or anyone that spent some seat time in the SC.
George
81 SC (sold)
Old 07-31-2006, 02:40 PM
