carreraken's Avatar
AC Compressor spitting grease...
85 911 with factory air set-up.
Whenever I run the AC, I find a streak of grease on the underside of the engine lid. I presume it's worn, but is this something that can be 'rebuilt' and repaired or do I need to replace the entire compressor?...
Thanks,
Ken
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 07-31-2006, 10:30 AM
Detached Member
Hugh R's Avatar
You can get it rebuilt, probably easier and doing it yourself if you don't have the right pullers and such. If its the original York, why not get a new Sanden Seiko? You'll have to pull a vacuum and recharge with R-12 unless your converting to R-134. You have to have an EPA license for R-12.
Hugh
Old 07-31-2006, 11:32 AM
Replace with a new seal. Might also need a sleeve to prevent the shaft threads from tearing the seal when installing it.
A more efficient compressor would be nice too.
Sherwood
Old 07-31-2006, 03:07 PM
carreraken's Avatar
Thanks for the info! Gotta love this site!
k
Ken
06 Cayman S - gone
Old 07-31-2006, 03:18 PM
Used Up User
imcarthur's Avatar
When it throws oil like that it is the shaft seal. See the write-up in the tech section on rebuilding. $30 worth of seals. I have the seals but haven't gotten to mine yet, but it does look reasonably easy.
see AC Kits for seals.
Ian
'87 Carrera Cab
Old 07-31-2006, 03:24 PM
