mca mca is offline
mca's Avatar
Scraping Fan Housing
I have some very noticeable scrapes on my fan housing right at the bottom - dead on with the z mark. I colored them in with permanent black marker in order to determine if it was past damage. I kept checking for a few consecutive days and the marker had not been scuffed off. Then, I checked about a week later and the marker had been scuffed off.
From reading past posts, it seems as though the following could be possible causes:
1) Chipped fan blades cause unbalanced fan - I have 3 chipped blades. Really? Can these really become THAT unbalanced?
2) Worn out alternator bearings
3) Cracked fan housing
4) Bent pulley shaft
When I remove the fan belt and hand spin the pulley, I can't hear any significant grinding noises coming from the alternator bearings. The alternator only has 22k on it. Can bearings wear out that fast? Also, when I hand spin the pulley, should it be compelety quite? I can hear a little, very very very faint grumbling ... but not significant at all.
Today I went ahead and loosened my fan belt by swapping 1 shim from the outside to the inside. Can a overtightened fan belt result in scraping?
Thanks for any and all help. I have a new fan coming but I don't want to install it if something is out of whack - last thing I want to do is chip a $200 used fan.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 10-12-2007, 07:24 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Most likely a cracked fan housing... pretty common with these magnesium housings... only option is to replace it ( you can try to weld... but best to just replace...)
I just went through the same situation... alternator was fine...
See the lower left corner in the photo...
And when I removed it there were additional cracks around the housing...
Here is my thread on that: Alternator issues
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 10-12-2007, 09:10 AM
Less brakes, more gas!
euro911sc's Avatar
Also, if you tighten the fan housing strap too much your housing strays from concentric circular to ovular and the fan blades will scrap the inside of the fan housing... Your engine will literally scream out when this happens... don't ask how I know...
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-12-2007, 07:06 PM
mca mca is offline
mca's Avatar
Best regards,
Michael
Thanks a ton ... both of you.
I pulled my fan housing out in order to get a look at my cylinder heads as I am chasing a temp problem. The alternator strap WAS quite tight. I don't have any cracks on the housing. So it was probably due to the strap.
Also, the fan spins freely with no drag ... but every so often I can hear a little bit of faint grinding ... I mean FAINT. The alternator only has 25K on it. How long do these usually last?
Old 10-16-2007, 06:24 PM
A properly rebuilt alternator should last longer than that I would say at least 50,000, but my ford Focus Alternator only lasted to about 30,000 and the original alternator in my Mustang has 97,800 on it , I pulled my 911 alternator at 97,000 ,but was previously rebuilt because it had Chinese bearings in it but I don't know when that was. So maybe from this reply I probably did'nt answer your question.
85' Carrera
92' Mustang 5.0
02' Focus ZX3 08' FJ Cruiser
Old 10-16-2007, 07:50 PM
Information Junky
island911's Avatar
...is my bet. Bearings are load sensitive --over load them (too tight belt) and they will wear prematurely.
Try lifting & spinning the fan. (belt off) If it no longer scrapes the bottom, then the bearings are sloppy.
Old 10-17-2007, 01:14 AM
Driving member
jester911's Avatar
I had this problem. I was told by a shop that I needed a new alternator. After close inspection I realized some debris got trapped in between the fan and housing. It caused a burr to stand up on the housing which would sometimes touch the fan blade.
I used course sandpaper and sanded down the area and went to finer sandpaper to make it smooth. This has been over 5 years ago and it still going strong. Oh and I don't go back to that shop any longer. YMMV
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 10-17-2007, 04:39 AM
mca mca is offline
mca's Avatar
Do worn alternator bearings get louder and louder with more wear?
I have the alternator out of the housing unit. If I spin it, should there be ZERO noise?
Old 10-17-2007, 06:30 AM
Information Junky
island911's Avatar
Worn bearings make noise. THe key, for you, is to check for slop. ---rock the pulley up & down, and you should be able to feel the slop. If no slop, do as Jerry suggests above.
Old 10-17-2007, 09:23 AM
Won Won is offline
Won's Avatar
I had the same problem; simply tightening the little nuts that hold the alternator on to the fan housing did the trick for me.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 10-17-2007, 10:15 AM
I doubt the problem is the alternator bearing or shaft if the fan is scraping only at the bottom of the fan shroud.
Try tightening the alternator nuts opposite of the scraping area. This will pull the fan away from the shroud and will stop the scraping. Seriously, try it and it should work.
Old 10-17-2007, 05:37 PM
Maybe the alternator is not properly aligned in the shroud. When pressing it onto the bolts, it must be pressed to the flange below or it won't be true inside the shroud, cuasing uneven spin.
Paul
Paul
'87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff.
'96 993 cab (gone, oops); '82 SC (gone)
Old 10-18-2007, 04:46 PM
3.2Carrera's Avatar
i am currently having the same problem w/ my car, but it only scraps( makes a noise) when i use the lights or the A/C. I just had the alternator bearing replaced, but i have a new pulley and my fan and housing was just repainted, I dont think its the bearing , i am going to take mine apart on tuesdays, i will keep you posted, i think, it may just have to be replaced. any other suggestions???
Old 10-18-2007, 07:40 PM
