Rob Channell's Avatar
Question 993 Heat Exchanger on 3.2 nut problem
OK. So of all the people that have installed a set of 993 heat exchangers onto a Carrera 3.2 motor:
How in the world did you get the nut on? You know the one I'm talking about.
For those that don't, when you rotate the flanges on the 993 exchanger for the passenger side, you lose the use of the through holes to reach the nuts for installation. The front and rear exhaust ports are reachable and the inside nut on the center port is doable, but the outside nut on the center exhaust port is impossible to get. I was hoping the exhaust was stiff enough that it would seal OK, but I have an exhaust leak that I need to get fixed. Did anyone install much longer exhaust studs and then use a really thick spacer between the head and heat exchanger? Or is there a special tool that some of you have designed to get this nut? I don't know any people locally with pencil lead thin fingers with 7 joints.
It's kinda like trying to crucify yourself. It won't work. There's no way to get the last nail in.
Help.
Rob Channell
One Way Motorsports
1979 911SC mostly stock
1972 911T Targa now with a good 2.7
1990 Miata (cheap 'n easy)
1993 C1500 Silverado (parts getter)
Old 07-30-2006, 08:52 PM
Bueller..........anyone.................anyone?
Rob Channell
One Way Motorsports
Old 08-01-2006, 07:34 PM
PRO Motorsports
Tyson Schmidt's Avatar
You'll need to buy that special wrench that has an open end wrench on one end, and a socket that flexes on the other end. That's about the only tool that works.
I have the full set from Snap-On, but Craftsman makes a knock-off now, and are way less expensive.
I used the copper coated exhaust lock nuts in 12mm hex head for extra clearance. The 13mm are just a little too big for working around in the tight quarters.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 08-01-2006, 08:49 PM
CBRacerX's Avatar
It is just a plan old PITA. First time I did it under the car. The next time will be with the engine upside down on the stand (whew!).
For sure use the 12mm nuts.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 08-01-2006, 08:53 PM
bigrubberjeep's Avatar
Good info!
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 08-01-2006, 09:42 PM
Thanks, guys.
Do you mean this type tool (in the right size)?
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=72023&group_ID=18138&store=snapon-store&dir=catalog
Rob Channell
One Way Motorsports
Old 08-02-2006, 07:46 AM
I just did this yesterday and it ended up being pretty easy - or easier than I thought it would be after reading the threads.
I used the Sears 1/4 inch drive universal joint with built in 12mm socket, and a new Sears tool called a Vortex socket. It allowed me to slide the 12mm Vortex socket over the stud and nut on the passenger side middle stud and then use the ratchet that came with it to tighten it. I had to reach around the outside and back in from the top with my right hand to hold the ratchet up while I tightened with my left hand, but it worked well.
I used the universal and socket to get it all started before moving to the Vortex.
Hope this helps.
I used the copper 12mm nuts all the way around.
Now I need to figure out what muffler to use. Any suggestions?
I'd prefer a high flow but quieter dual in, single out or dual in dual out.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 10-18-2007, 04:58 PM
The tool will help, but patience and persistence are the other two essential tools for dealing with that %$@#*%! nut. My engine was upside down on an engine stand and I still had a bear of a time with it.
Old 10-18-2007, 06:32 PM
