Mystery Washer
I found this washer under my car and can't figure out where it came from. The only thing I've done is a partial engine drop and I removed the pedal cluster when I replaced both the master and slave cylinder for the clutch. Does anyone recognize this? BTW, everything seems to be working fine.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 07-29-2006, 09:42 PM
bump....btw, it's a relatively thck washer...not cheaply made by any means.
Buck
'88 Coupe, '87 Cab,
Old 07-30-2006, 12:48 PM
randywebb's Avatar
did it break? or made like that?
found at front or back of car?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-30-2006, 03:11 PM
I was clearly made like this from it's appearance, the gap is a cleanly machined section and the center part has been machined as well. I found it about where the shifter connection would be located but the car had moved countless times so it's really hard to say for sure. I don't recall it being part of the pedal cluster when I removed the two bolts from under the car but could it have been related to the protective pan that has to be removed to get to those bolts? I don't recall anything on the shift coupler...
I guess it could have been sitting there for 20 years...it's my wife's old house she inherited so I anything's possible but I think I'd have noticed it at some point.
Buck
'88 Coupe, '87 Cab,
Old 07-30-2006, 04:53 PM
Non Compos Mentis
I think your wife tossed it under there just to freak you out.
It's probably from the sewing machine.
Old 07-30-2006, 04:57 PM
Ova Day
msterling's Avatar
It is........................... the letter "C"
You have a "C"arrera, right? Stick that puppy back on.
Mystery solved.
No need to thank me.
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 07-30-2006, 05:02 PM
Maybe I should attach it to the hood. Should I use JB Weld or could someone recommend a more appropriate epoxy? I'll need someone to put together a template so it's aligned properly. I'd hate to be made a fool of the next time we meet at Starbucks.
Buck
'88 Coupe, '87 Cab,
Old 07-30-2006, 05:57 PM
Priced-out of Porsches.
mmastro's Avatar
Oh, Oh, I know this one!
It's the slotted cupped washer that holds the pushrod in the master cylinder bore (pics are from an ATE MC from my BMW 2002).
Mike
SoCal
Old 07-31-2006, 06:03 AM
That's it! The one I found was pretty dirty so it must have come from the old master cylinder I removed and not, hopefully, the new one I just put in. I knew someone on the board would recognize the part!
Thanks a million,
Buck
'88 Coupe, '87 Cab,
Old 07-31-2006, 06:16 AM
mmastro's Avatar
Cool....
Have fun!
Mike
SoCal
Old 07-31-2006, 06:30 AM
