901 transmission rebuild question
I am rebuilding my 901 transmission and can not find a new lockplate for the drive shaft nut. Any suggestions? Would old plate with tab missing and locktite do the job?
Stressed Member
Robert-
Do you mean the one on the input shaft? Cut away the old, bent portion of the tab. File edges smooth and flat. Clean carefully. Install tab and nut, and bend some other portion of the tab to accomplish locking. -Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
obsolete, but you could make one from sheetmetal if you're patient. without the tooth, they don't work so well.
John
Thanks for great suggestion, made one and while it won't win any artisic awards it worked fine. Thanks again. Bob Shafer |
