-   -   How to? Flex brake line connection (http://forums.pelicanparts.com/porsche-911-technical-forum/296409-how-flex-brake-line-connection.html)
elflamo 08-01-2006 08:01 AM
Hi all,
I´m installing these new flex brake lines and got lost on how the u-shaped bracket on the front strut should be positioned. I now have it installed like in the picture, but this leaves quite a bit of thread exposed on the hard brakeline (to the caliper) and it looks like it´s not a real firm fit? I´ve checked with the original old flex lines, but seem to run into the same problem. Am I doing somwthing wrong here?
Many thanks!
Dennishttp://forums.pelicanparts.com/uploa...1154444472.gif
Gunter 08-01-2006 08:45 AM
Very good sketch.
What year/type car?
Cannot find any details in my Bentley SC Repair Manual.
imcarthur 08-01-2006 08:48 AM
I just did my fronts last weekend & mine was the same (1987). It came off that way & went on the same. Yes, some threads are exposed. Maybe it's a slightly tapered fitting?
Ian
elflamo 08-01-2006 10:45 AM
Thanks for the replies guys.
Gunter: it's 1972 2.4S, but I guess many more models have this construction.
I'm a bit concerned if this is really how it's supposed to be, as I would assume that this connection should be a firm one. I'm only getting it snug when I 'overbend' the u shaped bracket.
I'll check out the connection on the 911 of a friend of mine, but I would appreciate any more insights from more people 'in the know'.
Cheers
Dennis
cbeers 08-01-2006 11:13 AM
I am not sure this picture will help you, but it's all I have at work....
http://forums.pelicanparts.com/uploa...1154455992.jpg
-Chris
cbeers 08-01-2006 11:14 AM
wait, found another.
Might be just as useless though :)
http://forums.pelicanparts.com/uploa...1154456036.jpg
-Chris
elflamo 08-01-2006 11:30 AM
Hi Chris, thanks. This, however, isn't the mounting position I'm referring to. I'm referring to the bracket on the strut (the area that is just not shown in your pictures :p
Dennis
cstreit 08-01-2006 11:58 AM
It's not the threads that seal the fluid in, it's the bubble flare on the end. The threads just help tighten it down. There's nothing wrong with your install. Snug it down and check it for leaks whith someone pressing hard on the pedal
elflamo 08-01-2006 12:02 PM
Hmm, will check on an untouched car. Will let know how it works out.
Dennis
Early_S_Man 08-01-2006 12:12 PM
Dennis,
Your diagram is accurate ... the strut end of the junction is depicted on p. 400-2 of the Bentley 3.2 Carrera manual using an incorrect 1969 graphic of a 911E hydropneumatic front suspension! Also, see closeup on p. 401-13.
http://forums.pelicanparts.com/uploa...1154459532.jpg
elflamo 08-01-2006 01:02 PM
Thanks Warren, this really helps. I'llstick with what I have and pay extra attention when making the brake system operational
Dennis
