How to? Flex brake line connection
Hi all,
I´m installing these new flex brake lines and got lost on how the u-shaped bracket on the front strut should be positioned. I now have it installed like in the picture, but this leaves quite a bit of thread exposed on the hard brakeline (to the caliper) and it looks like it´s not a real firm fit? I´ve checked with the original old flex lines, but seem to run into the same problem. Am I doing somwthing wrong here?
Many thanks!
Dennis
Old 08-01-2006, 08:01 AM
Somatic Negative Optimist
Gunter's Avatar
Very good sketch.
What year/type car?
Cannot find any details in my Bentley SC Repair Manual.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-01-2006, 08:45 AM
Used Up User
imcarthur's Avatar
I just did my fronts last weekend & mine was the same (1987). It came off that way & went on the same. Yes, some threads are exposed. Maybe it's a slightly tapered fitting?
Ian
'87 Carrera Cab
Old 08-01-2006, 08:48 AM
Thanks for the replies guys.
Gunter: it's 1972 2.4S, but I guess many more models have this construction.
I'm a bit concerned if this is really how it's supposed to be, as I would assume that this connection should be a firm one. I'm only getting it snug when I 'overbend' the u shaped bracket.
I'll check out the connection on the 911 of a friend of mine, but I would appreciate any more insights from more people 'in the know'.
Cheers
Dennis
Old 08-01-2006, 10:45 AM
I am not sure this picture will help you, but it's all I have at work....
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 08-01-2006, 11:13 AM
wait, found another.
Might be just as useless though
-Chris
1998 CR500
Old 08-01-2006, 11:14 AM
Hi Chris, thanks. This, however, isn't the mounting position I'm referring to. I'm referring to the bracket on the strut (the area that is just not shown in your pictures
Dennis
Old 08-01-2006, 11:30 AM
Super Moderator
cstreit's Avatar
It's not the threads that seal the fluid in, it's the bubble flare on the end. The threads just help tighten it down. There's nothing wrong with your install. Snug it down and check it for leaks whith someone pressing hard on the pedal
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-01-2006, 11:58 AM
Hmm, will check on an untouched car. Will let know how it works out.
Dennis
_____________________________
1972 911 2.4S Black on Black, Recaro's, SSI, MFI, dual pipe exhaust, currently running in after engine rebuild!
Old 08-01-2006, 12:02 PM
Early_S_Man's Avatar
Porsche Crest
Dennis,
Your diagram is accurate ... the strut end of the junction is depicted on p. 400-2 of the Bentley 3.2 Carrera manual using an incorrect 1969 graphic of a 911E hydropneumatic front suspension! Also, see closeup on p. 401-13.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-01-2006, 12:12 PM
Thanks Warren, this really helps. I'llstick with what I have and pay extra attention when making the brake system operational
Dennis
Old 08-01-2006, 01:02 PM
