Help on adding a front oil cooler for 72T
Does anyone out there have information and/or pics on adding a front oil cooler to a 1972 911T. I have installed a 2.7L with about 225hp? and oil temp is now to #%@* HOT. Thanks in advance for any info or pics that you all could provide. :confused:
I did this upgrade using the Elephant Racing parts. If you go that route, it is more or less a complete solution. The supplied bracket was a pain to adapt to the earlier sheetmetal of the pre-'74 car, so I just made my own. You'll need to check your oil tank to see if it has a plug in the bottom (next to the drain plug) where your return line will attach. You'll also need to send your oil filter console out for machining to accept a thermostat. Everything else was straightforward/bolt-up. Check Elephant Racing's site, call Chuck, and do a search here on the forum for more info.
If you don't feel like spending $2k, I've got a more or less complete aftermarket Aeroquip/Mocal system I keep meaning to sell. |
hang on!! i'm writing an article on my project for this exact application. I should be done tonight.
please post!
dtw, pls. let me know if you decide to sell your aeroquip/mocal oil cooler set-up. i also sent you a pm.
thanks! |
Matt,
Please let me know if you have any interest in trading notes on this, I have also been through this installation this year with a '72T. Benji, Thank you for your message, I responded via email. |
Thanks for all the info so far. I have a front oil cooler that mounts in the front bumper (RSR type) and the oil lines from a 87 Carrera to reach back to the oil tank. I am really interest in the plumping at the therostat and oil tankI also have the oil cooler from the 87 Carrera for sale if anyone needs it. How much?
Thanks |
i'm still writing it. i'll have it all pretty and have a new thread going tomorrow night. i'll post a link here to the new thread.
Dave my article should be very complete. we'll chat if you still want to go over some things. |
72 front cooler
bump!
| All times are GMT -8. The time now is 07:43 PM. |
