evan9eleven's Avatar
Oil tank corrosion?
So, I replaced my oil level sender a few months back as winter was setting in, and am just now getting around to repairing the wiring to it, along with installing a new rubber boot over the connection. Before I replaced the sender last fall I used some degreaser on the oil tank to clean it up so no dirt would end up in the tank.
When I looked at the tank tonight I noticed rust on the nuts for the sender, no big deal, but there appear to be a few rust spots on the tank too-- along with some glistening droplets of something. OIL! Wet droplets. As though oil is weeping through the tank walls. This can't be, right? Mine is a nearly rust-free car, so its not seen winters and salt so I'm puzzled. The car hasn't been run in two months. Pics for reference:
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 02-02-2015, 09:59 AM
If it looks like a duck, walks like a duck and quacks then it is quite likely to be a duck
If it is oil then the only place it can from will be inside the tank, just be bold and remove the sealant and check it out.
Old 02-02-2015, 10:14 AM
Wer bremst verliert
JohnJL's Avatar
The tanks are coated with copper in an attempt to delay corrosion, but it still happens. Water accumulates in the tank from the hot-cold cycle condensation (ever see the yucky yellow mayo/foam inside your oil cap?) Some degreasers are also caustic so can cause or make a problem worse. Ever leave some bolts in a degreaser vat for a few months? They corrode...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-02-2015, 11:07 AM
Mark Salvetti's Avatar
What's odd is those leaks (if that's what they are) seem to be pretty high up on the tank wall. What does the bottom of the tank look like? If it was condensation inside the tank that caused this, wouldn't you expect the worst damage at the lowest point?
Mark
1979 911SC Targa
Old 02-02-2015, 11:36 AM
pors1968's Avatar
It might be some degreaser Under coating but it look it been corroded with dirt road.Top must be worst.
Old 02-02-2015, 03:56 PM
Gav Gav is offline
Is it definitely oil?
Perhaps the degreaser has reacted with the body deadner?
Old 02-02-2015, 05:03 PM
safe's Avatar
They seldom rust from the outside. If they leak there is a lot of rust on the inside.
Start looking for a replacement tank.
Magnus
Old 02-03-2015, 11:19 AM
I was afraid of that. I'll inspect more closely when I have the car in the air this weekend and report back, but the substance sure seems to be oil. What would allow the inside of an oil tank to rust first is an obvious question... humid climate and not being run for months on end in winter is my best guess.
2004 Boxster S
Old 02-03-2015, 11:32 AM
Send a message via Skype™ to Porboynz
I will place my money on it being the under seal bleeding or some thing other than internal rust. Reasoning that rust would be at the top of the tank.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 02-03-2015, 09:16 PM
porschetub's Avatar
I have one like that and only recovered the console,it had been brazed,soldered and then covered in sealer ,the inside cleaned up nice till i found the outside was like a battle ground.
Hated the dishonest seller for a while,till I found the console as in perfect condition and now worth good money
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 02-04-2015, 01:14 AM
safe's Avatar
Well, I assume that evan9eleven is correct in that it is oil, but the area might need a cleanup to confirm.
It is a little strange cause I thought that an 81 would have a stainless oil tank. On the other hand they can corrode too.
Magnus
Old 02-04-2015, 01:30 AM
After doing some reading I see that the later tanks are often mentioned as being stainless. Yes, stainless can corrode if subjected to road salt and other nasty stuff... but it takes some doing so I'm even more surprised if my tank has rusted through. I also read that the vapors in our oil tanks contain a lot of byproducts of combustion that are corrosive too, but again I would expect to see this effect more at the top of the tank. I'll definitely have a closer look ths weekend.
2004 Boxster S
Old 02-04-2015, 11:59 AM
